Hey ARK,
First off, thanks for taking the time to write this up, this will answer alot of questions for many people!!!
You may want to clarify in the spacer section of your post in regards to the front lifts. You mention that you actually get double the lift in the front when a spacer is installed and the rear stays the same. When I first read it through, I was even a little confused with the information on the "front spacers", more specifically the net lift that you would get.
I don't think that with a 2.5" spacer, you will get double, i.e. 5" in the front, if that makes sense. I know that you will get double in the front if you installed a 1/4", 1/2", 1", or maybe even the 1.5", but not a 2.5". Hopefully what I'm trying to say makes sense. If I'm wrong, please correct me! Only trying to help make the post as clear as possible and provide constructive help!
Also, what about adding more information about tire size fitting with Body Lifts? I see that's on there with both a spacer & body, but what about doing one for only body lifts? Just a thought!
Great post!!!!!!!!!!!!!!
'05 Black Limited V8 with XREAS / LED Interior & Exterior Swap / Custom LED Ground Lighting Strips Mounted Below Running Boards / HCF Delete / AFE Air Filter (Dry) / Optima YellowTop / DDM Tuning 35W 5000K HID Fogs / Weathertech Digital Floor Liners & Cargo Mat / 20" Enkei Wheels / Tacoma Skidplate / Built In Headrest DVD Monitors with Custom Covers / iPod Adapter / Pioneer AVIC-D3 HU with Navigation / PassPort 9500xi, Hardwired / 50% Tint / Custom White/Blue LED Gauges & HVAC /
Coming Soon: Lift, UCAs, 1.25" Spidertrax (have 'em, just waiting on install)
