In order to avoid loading multiple threads into the Documentation and Reference Thread, I wanted to assemble all the different ABS threads into one that we could load in there, so here goes:
ABS Disable on E-locked 4Runners - '96-'00 and some pre-wired non-locked's)
AKA the Yellow-Blue Wire Mod
ABS Switch - Easy, effective and simple
ABS Disable on non-E-locked Runners - '96-'00 (2 methods)
ABS Disable on older 3rd gens
Updated thread:
ABS disable V2.0 for older 3rd gens (On/off on the fly)
ABS, VSC, TRAC Disable on '01-'02
Disable VSC, TRAC, and ABS without damaging factory wiring
VSC, and TRAC Disable on '01-'02
Disable VSC/TRAC Only
Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems - YotaTech Forums
Disable VSC and TRAC but not ABS on '01-'02
AndyMod 2.0. ABS Remains Active. - YotaTech Forums
A couple guys mention disabling VSC withouth disabling ABS or TRAC, If anyone has a write-up for that, post it and I will add it. Same for any other methods of disabling any of these, post them here and I will add them.
