View Single Post
Old 12-07-2011, 11:46 AM
LargeOrangeFont LargeOrangeFont is offline
LargeOrangeFont is on a distinguished road
Originally Posted by jaybird93000 View Post
So you have bilsteins up all the way and fit 265/65 duratracs?? So could i fit 275/6 duratracs with minor rub if i were to do bilsteins???
No I have the Bilsteins set to 1.75 in front, not 2.5 which is the highest. That is with stock springs.
I don't have Duratracs, I have Falken Rocky Mountain ATS, they are not as agressive.
Depending on your wheel size and offset (you did not mention if you are going with a 17 or 18 inch rim), the 275/65 Duratracs will fit at the 2.5 inch lift setting easily, and probably at the 1.75 setting with a little trimming if you are running 18 inch wheels. Again this will depend on you wheel size, offset and spacer setup.
If you are talking a 17 inch wheel OEM rims with a 275/65/17 tire and spidertrax spacer the answer is yes, they will fit at 1.75 or 2.5 without any issue. It might need very minor trimming/fender liner adjustment and the 1.75 setting.
LargeOrangeFont is offline   Reply With QuoteReply With Quote
