README:
You can embed 720p by using the txt code below.
1) see quote below,
replace the first '
[' with a '
2) replace the identifier text
FNNWysNIZMQ with your YouTube video's code tag, every video has one
3) the video will now post embedded as 720p once you paste the modified text into T4R
[iframe width="853" height="480" src="http://www.youtube.com/v/FNNWysNIZMQ&hd=1" frameborder="0" allowfullscreen>
You can ALSO embed 480p youtube videos into T4R using the text below:
*** You will want to
replace the char '0' with 'o' using the code below.
*** I had to change it to a 0 or you would not be able to read it in the forum because it would have shown as a video.
*** The center
JFwCCL0Vh6U should be changed to the YouTube_ID video ID.
There
might be a special char '-' or '<' or '$', if there is then copy it into the code since it is part of the YouTube_ID.
[y0utube]JFwCCL0Vh6U&hd=1[/y0utube]
You can download a permanent copy of ANY YouTube video ...
*** even 720p using a freeware program called JDownloader.
*** Simply download it, install, restart, then right click any link --> copy, then in JD right click the download and choose download link.
You can embed common videos from sources like SouthParkStudios & Vimeo by doing this: ...
*** On the source site click the "embed" button --> copy.
*** You should be copying text that looks like ... [iframe ---- text iframe]
*** Paste the entire iFrame text into T4R
< iframe ... text ... iframe >
****** 720p TEST ********
HD LINK:
Tool - Vicarious - 1080p - YouTube
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish
treasonous thief.
