View Single Post
Old 02-01-2012, 07:13 PM
DragonRunner DragonRunner is offline
DragonRunner is on a distinguished road
Originally Posted by J.A. View Post
In order for the fog lamps to light up, the fog relay needs to be energized. To become energized it needs both positive and negative available at the coil. Part one brings 12V+ positive to one side of the coil anytime the ignition is on. Since negative is at the other side of the coil anytime the headlight dimmer stalk is in the low beam position the fogs work "anytime" as long as you dont choose the high beams. As soon as you switch on the high beams or the "flash to pass" mode, then negative is removed from the coil and hence the need for part 2. Part 2 brings ground (negative) to the respective side of the fog lamp relay coil whenever the fog switch is on regardless of the headlamp dimmer position.
In that case can I ground the other side of the coil at the relay vice tearing into to steering column?
2018 White TRD Offroad Premium w/ KDSS; Shrockworks sliders; Method M701; Falken AT3W 265/70/17 SL; OrangeBoxx MOLLE panel (R); CanvasBack cargo liner w/ red stiching; Red/Black parachord grab handles; GOBI rack & ladder; Morimoto Elite HIDs (50W 5500k); Infinity REF 3032 3.5 speakers (dash location)
(SOLD) 2004 Blue Sport V8; Anytime Fogs; CanvasBack cargo liner; maglight overhead mount mod
DragonRunner is offline   Reply With QuoteReply With Quote
