Rust bleeding through paint on rear hatch
I'm a bit miffed about a minor corrosion problem.
My wife's T4R has about a dozen small spots of rust coming through the paint. All are on the rear hatch. In a couple of cases there is a blister forming in the paint with no bleed-through. All are small. The rust spots are 1-2mm (<1/16"). The blisters are 3-5mm (<3/16").
The dealer took a look and readily agreed to get it into their body shop on Monday. I'm confident the sanding/painting will be fine - it's just that I hate to repaint. It's never quite as good as OEM (as OEM should be).
Has anyone else experienced this same problem?
____________________________________
2011 Limited, Blizzard Pearl, 3rd Row.
