Originally Posted by Shine4JC
Thanks Guys! Checked all the fuses and all is well. I have the original bulbs at home so I'll try that next. I've NEVER had both bulbs go at the same time, although I'm sure it happens so I may be over reacting here. Thanks for the schematic but where's the dimmer relay located? Appreciate your help and need to resolve the issue ASAP because I know I'll get pulled over for running just the fogs or high beams.
Bottom left of engine room relay/fuse block (see page 22 in link):
http://www.ncttora.com/fsm/1996/SIL/...c/relayloc.pdf
You should be able to hear/feel it cycle as someone works the stalk. If it is cycling, and fuses are good, bulbs are almost a sure thing. The both bulbs thing happens all the time. SilverStars burn out really fast, they are on NEVER AGAIN status with me.
My Backyard Frame Swap
