Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 11-09-2014, 08:22 PM #46
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Thanks for the tip. I will look into an upgraded oil pump, I would not want to experience any problems with the block in the future. Going to grind the crank for .010" larger rod bearings so the bottom end should be pretty solid in boost.
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 11-14-2014, 11:50 PM #47
Moderator
Real Name: James
Moderator
Real Name: James
Top came back, wrong color. I understand this is panel painting but this was just an awful match. The people who destroyed the headliner were also responsible for mixing the paint, another mistake letting a body shop do the work.
This time around, my choice of paint shop is mixing up a better match. The paint should be ready by Monday and the top will get resprayed.
Untitled by cobblewagen, on Flickr
Here's the absolute JOKE of a headliner they installed... not having any of this... no.
Went on craigslist and found a Targa part out. Bought the headliner. I sent it out today to get rewrapped.
Replacement Targa top seals from Toyota
Sunvisors already rewrapped... I like them. The headliner is getting done with the same fabric.
No mirrors on these.
Folding mirrors should be done and back from paint next week
Old 11-18-2014, 04:49 AM #48
Moderator
Real Name: James
Moderator
Real Name: James
behold, the canyon:
Moving along
Dash out
Fixing up a little damage, glue and clamps.
Installed
Replaced the broken ignition cylinder/steering wheel lower cover.
From canyon to flatlands...
Going to repaint that cowl and install new wipers sooner or later
Headliner rewrapped
Old 11-18-2014, 11:26 PM #49
paddlenbike's Avatar
paddlenbike paddlenbike is offline
paddlenbike will become famous soon enough
Normally I prefer canyons to flatlands, but not in this case.
Nice work as always--you're the type of guy I would want to buy a car from.
2000 4Runner 4WD - lifted, e-locked, TRD supercharged 5-speed | MY BUILD THREAD
paddlenbike is offline   Reply With QuoteReply With Quote
Old 11-21-2014, 04:43 PM #50
Moderator
Real Name: James
Moderator
Real Name: James
Thank you, your car was a very clean example so good feedback from fellow supra owners is especially nice.
Old 11-21-2014, 04:48 PM #51
Moderator
Real Name: James
Moderator
Real Name: James
Got a set of door panels. The passenger one is in excellent shape compared to mine. The driver's one has a big damage spot, but still better than mine regardless. Mine have armrest tears, these do not.
And last I picked up some paint, all matched to the car.
1/2 pint for the top and mirrors
touch up bottle
8oz spray can for future projects
Old 11-22-2014, 04:51 AM #52
Moderator
Real Name: James
Moderator
Real Name: James
The driver door panel vinyl in my car isn't pretty, still looking for just the right panel to replace it. In the meantime, I took the carpeted middle and lower sections which are less faded.
Old (top)
Old (bottom)
installed on the panel, along with the lower portion
Swapped in the speakers from my donor car while I was at it.
Also replaced the malfunctioning lock switch with that from my donor car
Passenger side I replaced the entire panel and swapped speakers.
Old panel
new panel
One more for the road... that dash
Old 12-01-2014, 03:59 AM #53
Moderator
Real Name: James
Moderator
Real Name: James
Got my targa top back... again
Installed headliner
It's starting to look like a roof again, just gotta install the side trim and seals.
Last, a friend bought a new 4Runner TRD Pro, I cut this from the plate frame. I like it, looks like an old school Toyota logo.
Old 12-03-2014, 11:55 PM #54
Redswan's Avatar
Redswan Redswan is offline
Real Name: MojaveMike
Redswan is on a distinguished road
Redswan's Avatar
Beautiful Supra!
Redswan is offline   Reply With QuoteReply With Quote
Old 12-09-2014, 04:16 AM #55
Moderator
Real Name: James
Moderator
Real Name: James
Originally Posted by Redswan View Post
Beautiful Supra!
Thank you sir, you've got a fine looking 4Runner yourself.
Old 12-09-2014, 06:11 AM #56
Moderator
Real Name: James
Moderator
Real Name: James
7MGTE coil pack cover without cracks
1UZ MAF
Shifter boot
R154 inspection cover
Competition clutches aluminum flywheel, south bend clutch
RC 550cc fuel injectors
Also installed the hood again to try out some hood struts
Parts car
Old 12-16-2014, 08:41 PM #57
Moderator
Real Name: James
Moderator
Real Name: James
A couple videos I put together.
Old 12-17-2014, 04:58 PM #58
Moderator
Real Name: James
Moderator
Real Name: James
Trying out a new interior photography method... inside the car with the cover on. When the interior's all ready, I'll do a nice shot showing the seats and center console, etc.
Old 12-17-2014, 09:54 PM #59
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Wow...quite impressive...I love those Supras...best looking by far IMO.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 12-22-2014, 08:54 PM #60
Moderator
Real Name: James
Moderator
Real Name: James
Got her up on jack stands.
@4Running Daily gave a helping hand.
Bell housing bolts:
Flexplate showing, trans out. View through shifter hole.
Ugly mother f*cker
Motor coming out, outside to set up the hoist.
7M-GTE out of the car.
Bro lean
Thanks for the help, Connor
93'-98' Toyota Supra Twin Turbo VS. Nissan Skyline R34 andyman32392 All Other Vehicles 30 08-22-2012 10:31 PM
Anyone use a Supra MAF??? caddyman Classic T4Rs 6 08-06-2012 12:45 AM
Turbo Vs Non Turbo Car Reliability hulk311 All Other Vehicles 18 03-23-2012 10:43 PM
Supra Koz All Other Vehicles 16 04-25-2006 04:06 PM
Tha New Supra BigHop All Other Vehicles 5 03-16-2006 09:47 PM
