02-12-2015, 10:40 PM
#46
Got a Ifs width rear to go in, and swapping my original welded 3rd back in.
Still haven't had time to work on my PS problems yet.
98' 4runner- SOLD
82' pickup; 35x12.50's, 30spline longfields, e-locker front, welded rear, 4.7's in the tcase, hi-steer w/ hydro assist, bobbed bed.
02-13-2015, 08:27 AM
#47
Stock pump? Is the restrictor drilled out?
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
02-13-2015, 12:56 PM
#48
Stock pump. I don't know for sure if it is drilled out, but it almost acts like someone drilled it out too much. I'm going to try another pump when it warms up a little.
98' 4runner- SOLD
02-13-2015, 01:15 PM
#49
Was going to say, I have a pump if you need it.
02-14-2015, 06:12 PM
#50
Thanks! i have a spare that should work.
do you think i should drill the restrictor plate on this one, or try it stock first?
98' 4runner- SOLD
02-14-2015, 06:14 PM
#51
So this happened yesterday..... F***er came out of no where.
98' 4runner- SOLD
02-14-2015, 07:49 PM
#52
I would, I think 13/64 is the recommended size.
And damn, how much damage did that limb do?
02-14-2015, 09:08 PM
#53
Ok cool I've got some 13/64 at work, I'll go ahead and drill it while it's out.
The limb didn't do too much damage. Just the headlight and and the trim around it. I think the grill will go back in place.
98' 4runner- SOLD
02-26-2015, 10:26 AM
#54
Real Name: Nelson
Real Name: Nelson
All man that sucks how's it doing did ya get a chance to get it fix
Off road runner
-Toyota 4runner
02-28-2015, 11:33 AM
#55
Haven't got around to fixing it yet. I'm debating weather or not i should do a 79' round headlight and grille swap instead of buying new parts to fix what i have.
98' 4runner- SOLD
02-28-2015, 11:40 AM
#56
Real Name: Nelson
Real Name: Nelson
If it was me I would fix it with the original grill and lights I like the round ones but the front of your truck looks like a beast like it was.. just my opinion.
Off road runner
-Toyota 4runner
02-28-2015, 04:09 PM
#57
@ 96 ToyRunner
Thanks for the motivation! i needed to get this done.
before i even saw your reply i went and found a 79 2wd grille and head lights. they should be in momentarily.
98' 4runner- SOLD
02-28-2015, 07:50 PM
#58
And done! not 100% sure if i like the 2wd grille, but it might grow on me.
everything fit relatively well, the only major thing that had to be changed was the turn signal plugs.
98' 4runner- SOLD
03-04-2015, 01:12 AM
#59
Real Name: Nelson
Real Name: Nelson
Looks good are the lights better worse then the other ones ...I also like the old Toyota emblems ..
Off road runner
-Toyota 4runner
03-04-2015, 08:41 PM
#60
continuing to follow along. liking the looks of the frontend
2002 4runner SR5 2wd
2005 Tacoma Prerunner 2wd
