Thread Tools Rating: Thread Rating: 13 votes, 4.62 average. Display Modes
Old 12-24-2017, 01:45 PM #181
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom has a spectacular aura about ChildrenOfBodom has a spectacular aura about ChildrenOfBodom has a spectacular aura about
Moderator
Real Name: James
I sourced a couple polyurethane bushings that fit the radiator mounts very nicely, using a medium durometer material that allows for some vibration dampening. The inner diameter is not the right size, but a couple short metal sleeves fixed that issue. There’s even a few grooves on the ID of the bushings for lubrication. I’m going to have to clean the radiator up really nice and maybe even a bit of solder/weld work on a couple spots. It does its job rather well, so repair is worth saving the money I’d have used on a new aluminum radiator. Perhaps it may be replaced with a better unit in the future, as the AC fan mounting is not accurately positioned.
Megan downpipe and HKS Super Drager catback removed. Polyurethane exhaust hangers are also going in to reduce movement near the exhaust tip, in an effort to prevent contact with the rear bumper. The Megan downpipe is angled poorly and brings the exhaust down too low, thus I may be considering modifying it with a pie cut to straighten things out. I plan to go single turbo in a year or two, that would be a great time to get a higher quality downpipe.
Doors coming apart.
Instagram: @jimharb
COB's '99 4Runner - 2.7L 3RZ-FE - TRD Supercharged - 4WD Conversion + R150F 5-Speed Swap - Base Model to SR5 Highlander
COB's '87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Bikini Top - 33" BFG M/T's - Mild Restoration
COB's '89 Supra Turbo Targa - 3.0L 7M-GTE - R154 - CT-26 57 Trim - 1UZ MAF/AFPR/550cc - ARP Head Studs - Metal Head Gasket
COB's '94 Supra Turbo Targa - 3.0L 2JZ-GTE - HKS Exhaust - GSC S1 Cams - Brian Crower Valve Springs - Restoration in Progress
COB's '99 Limited 2WD | COB YouTube
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 12-24-2017, 01:46 PM #182
Moderator
Real Name: James
Moderator
Real Name: James
Hatch, driver door, roof, and both fenders off to paint, then later the passenger door.
A peak at the product to be used… Sikkens Superior 250 2-pack Clear
Digging into the core support. Good lord… it doesn’t get any better!
Try not to look… whoever did this should never touch a welder ever again.
Drilling out some holes to redo this the right way
Instagram: @jimharb
Old 12-24-2017, 02:28 PM #183
Moderator
Real Name: James
Moderator
Real Name: James
Booger welds with little penetration to the metal below… holes drilled through the tie bar, welds from the frame rail up through the holes.
Instagram: @jimharb
Old 12-24-2017, 02:30 PM #184
Moderator
Real Name: James
Moderator
Real Name: James
New welds from the bottom layer up.
Instagram: @jimharb
Old 12-24-2017, 02:30 PM #185
Moderator
Real Name: James
Moderator
Real Name: James
Lower tie bar also welded via the drilled holes, but I didn't get a picture of that before application of the black seam sealer
ECU Wiring out through the firewall.
Instagram: @jimharb
Old 12-24-2017, 04:11 PM #186
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Simply epic man. I believe this thread might be the most detailed (pic heavy) restore thread on T4R in totality. You really show the huge amount of work goes into doing a proper restore. Clearly it doesn't hurt to have friends.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 12-25-2017, 12:26 PM #187
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Chuckles89 will become famous soon enough
Chuckles89's Avatar
Saved that last pic
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
My 1998 4Runner- V6 Manual, AISIN Hubs, Cable E-Locked, 265/75R16 KO2s and 235/85R16 STT Pros, Mostly Armored (336k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
Old 12-25-2017, 01:09 PM #188
Unner's Avatar
Unner Unner is offline
Unner will become famous soon enough
Unner's Avatar
Wow James, this is amazing. I've never been too big a fan on MK4's simply because of the stereotypical owners, and I don't like the way they look with all the body kits and what not that they usually have, but a stock MK4 looks really good. I love what you're doing with this, it's exactly what I would do, but I don't have the connections you do to have the body work done to such a high level. Can't wait to see it done!
2001 Toyota 4Runner SR5 4x4 - Not Stock, DD, Lifted, Armored, 260k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 12-26-2017, 03:38 AM #189
LiquidFlame LiquidFlame is offline
Real Name: Cody
LiquidFlame is on a distinguished road
Real Name: Cody
Still my favorite thread on this whole site. Not many people have the patience to do what you're doing to bring that car back to its glory. Cant wait to see more progress!
2002 4x4 Sport Edition at 190k, B&M transmission cooler, Borla muffler, CB radio, ScanGauge II, Rola roof rack, 20" bumper LED light bar, kicker subs, unknown rock sliders/steps, Tundra 5100s with 880s up front.
LiquidFlame is offline   Reply With QuoteReply With Quote
Old 12-27-2017, 06:18 PM #190
Moderator
Real Name: James
Moderator
Real Name: James
The amount of work is staggering, agreed. There's so many details that get overlooked in most threads, even in mine, but photos are just the best way to convey that. More text sure would help. Friends are definitely something to be thankful for.
Originally Posted by Chuckles89 View Post
Saved that last pic
The old Toyota fleet is strong, haha. There will be some serious photos taken once this thing is all done.
The owners man, I get you. There's a lot of great people, but just as many of "them." Most MKIV's make me want to gag, between the wavy body kits and tacky add-ons.
Thanks man, it'll be a pleasure to bring a finished product to this thread. I have some progress to report, hoping that it will all result in a clean, respectable MKIV!
That says a lot, especially since this isn't even close to done! Thank you for your patience as well, it has been slow, hopefully your time spent will be worth it when there's a finished product upon the pages of this thread.
Instagram: @jimharb
Old 12-27-2017, 06:34 PM #191
Moderator
Real Name: James
Moderator
Real Name: James
The motor has been waiting a little while to come out - a little Christmas motor pulling!
Hoist ready
Harbor freight 2 ton load leveler
Instagram: @jimharb
Old 12-27-2017, 06:34 PM #192
Moderator
Real Name: James
Moderator
Real Name: James
Pulling the car out of the garage just enough, before jacking it up and putting a couple blocks under the front wheels.
On the way out...
Instagram: @jimharb
Old 12-27-2017, 06:35 PM #193
Moderator
Real Name: James
Moderator
Real Name: James
Almost there!
A peek in the daylight.
Instagram: @jimharb
Old 12-27-2017, 06:50 PM #194
Moderator
Real Name: James
Moderator
Real Name: James
The first few parts have now received their first coat of primer.
Instagram: @jimharb
Old 12-30-2017, 12:48 AM #195
PrimtimeKenny_S550 PrimtimeKenny_S550 is offline
PrimtimeKenny_S550 is on a distinguished road
Great thread, It's nice to see the progression and commitment from a two year plus build. Chasing dreams!
PrimtimeKenny_S550 is offline   Reply With QuoteReply With Quote
COB's '89 Supra Turbo ChildrenOfBodom All Other Vehicles 166 09-26-2019 11:19 AM
Toyota Supra twin turbo 2JZGTE Engine 2JZGTE Engine swap? Rendell 3rd gen T4Rs 38 07-17-2017 02:31 PM
Catt's 98 Toyota Supra Turbo full build process CWebb All Other Vehicles 21 10-28-2015 04:38 PM
93'-98' Toyota Supra Twin Turbo VS. Nissan Skyline R34 andyman32392 All Other Vehicles 30 08-22-2012 10:31 PM
Turbo Vs Non Turbo Car Reliability hulk311 All Other Vehicles 18 03-23-2012 10:43 PM
