Thread Tools Rating: Thread Rating: 13 votes, 4.62 average. Display Modes
Old 02-05-2020, 05:16 PM #361
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom has a spectacular aura about ChildrenOfBodom has a spectacular aura about ChildrenOfBodom has a spectacular aura about
MY GARAGE
Moderator
Real Name: James
MY GARAGE
Front sway bar to frame brackets painted with SEM Trim Black.
Brand new bolts from Toyota.
Engine bay wiring harness cleaned up and ready for installation:
Brand new OEM hardware. Black zinc finish.
New 98 master. This accomplishes both a nice clear reservoir and elimination of the TRAC system.
New gasket to booster and new OEM nuts.
Brake lines are all cleaned up and ready for installation.
Instagram: @jimharb
COB's '99 4Runner - 2.7L 3RZ-FE - TRD Supercharged - 4WD Conversion + R150F 5-Speed Swap - Base Model to SR5 Highlander
COB's '87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Bikini Top - 33" BFG M/T's - Mild Restoration
COB's '89 Supra Turbo Targa - 3.0L 7M-GTE - R154 - CT-26 57 Trim - 1UZ MAF/AFPR/550cc - ARP Head Studs - Metal Head Gasket
COB's '94 Supra Turbo Targa - 3.0L 2JZ-GTE - HKS Exhaust - GSC S1 Cams - Brian Crower Valve Springs - Restoration in Progress
COB's '99 Limited 2WD | COB YouTube
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 05:32 PM #362
Moderator
Real Name: James
MY GARAGE
Moderator
Real Name: James
MY GARAGE
New TRD sway bars in red
Energy Suspension greaseable sway bar brackets with 90 degree zerks + red zerk caps, as well as red polyurethane bushings (As opposed to the black that Toyota supplies)
Front installed
Rear installed. New bolts on the KW's.
Took this time to install the targa seal against the windshield header, plus the front section of headliner, dome light, and sun visors.
Still keeping the plastic on the new A pillar trim until she's ready to drive
With coilovers and sway bars installed, the suspension is just about complete. The car is ready to sit on its wheels for the first time since November of 2018.
Coilovers at their lowest setting, just for ease of install. Will have to come up quite a bit for the engine to go in.
The front wheels poke out quite a bit with the 25mm spacers that were run with the stock TT wheels. There's some space between the spoke and caliper for the wheel to come in a bit.
My friend Harman, a machinist, brought over his gauge block set to do a front wheel clearance check. There is about 14mm of space between spoke and caliper. The current spacer is a 25mm, going to drop it down to 12mm with extended ARP studs to see what can be accomplished. May have to go down to a narrower front tire should the fender clearance still be an issue.
Another note - the external hex lug nuts have been swapped for internal hex. I'm going to have the new ARP studs shortened about 10mm to allow for the use of internal hex lugs all around. I don't like the idea of a socket scratching up the wheel.
Instagram: @jimharb
Old 02-05-2020, 05:44 PM #363
Moderator
Real Name: James
MY GARAGE
Moderator
Real Name: James
MY GARAGE
With the car on the ground, it was finally time to get it turned around. Installation of the doors requires ample space to swing the door fully open. The passenger side door is next.
The driver seat
It was at night, so photos are limited, but it was a sight to behold. Seeing the car outside of the garage was refreshing.
Almost looks like it's a complete car...
Can't help but take pics of it whenever I get home... by the light of my 4Runner lol
Ready for the passenger side door!
Instagram: @jimharb
Old 02-05-2020, 06:04 PM #364
Moderator
Real Name: James
MY GARAGE
Moderator
Real Name: James
MY GARAGE
The everlasting struggle of garage photography...
Justin's back to help hang one of the last body panels to go on.
After a quick wipedown
Passenger mirror is on
Door is assembled with new screw grommets and belt molding. The glass is just waiting for when the car has power.
I am getting major goosebumps... Soon she will return to the streets.
I'm going to contact a friend in the industry to hopefully get a new set of rotors and pads front and rear. I'm also going to try to find a good powder coating source to redo the OEM TT calipers in red.
Here the car sits, waiting for extended studs and new brakes. Hubs are cleaned up and will be shot with SEM Trim Black before the new studs go in. This way, the center hole on the Enkei wheels will show a black hub instead of an ugly rusted hub.
The new 12mm hubcentric spacer fits really well, but the stud length will not allow for any lug engagement. Holding the wheel against the spacer/hub by hand, it freely rotates without caliper interference. It has the caliper clearance of a German car (AKA - 1mm or so, super close!)
The front KW's are now adjusted to about 75mm of thread between the bottom of the perch and bottom thread. Pics of that will come after the studs arrive and I can put the car down on it's own wheels again.
Thanks for your time.
Instagram: @jimharb
Old 02-06-2020, 01:19 AM #365
Silver Supra's Avatar
Silver Supra Silver Supra is offline
Silver Supra will become famous soon enough Silver Supra will become famous soon enough
Great progress!! I remember putting mine back together after paint. It was very enjoyable and extremely satisfying when she was back on the road!
Can't wait for you to take the maiden voyage!
By the way - 285's up front and 315's in the rear.
5-speed swap stuff available here!
https://www.toyota-4runner.org/for-s...isc-stuff.html
Silver Supra is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 08:57 PM #366
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C has a spectacular aura about Ed_C has a spectacular aura about
Ed_C's Avatar
Real Name: Ed
Reading this thread makes me both happy and sad...
Happy seeing progress
Sad because mine's been sitting for several years
COB's '89 Supra Turbo ChildrenOfBodom All Other Vehicles 166 09-26-2019 11:19 AM
Toyota Supra twin turbo 2JZGTE Engine 2JZGTE Engine swap? Rendell 3rd gen T4Rs 38 07-17-2017 02:31 PM
Catt's 98 Toyota Supra Turbo full build process CWebb All Other Vehicles 21 10-28-2015 04:38 PM
93'-98' Toyota Supra Twin Turbo VS. Nissan Skyline R34 andyman32392 All Other Vehicles 30 08-22-2012 10:31 PM
Turbo Vs Non Turbo Car Reliability hulk311 All Other Vehicles 18 03-23-2012 10:43 PM
Copyright © 2019
