08-26-2020, 02:45 PM
#378
Real Name: Greg
Real Name: Greg
Man Bodom, I havent logged in in 2 plus years since I sold my runner. I am so glad to see you still have this thing! Its beautiful! I remember when it was two tone and you brought it home.
99 Runner-TBU, 265/75/16 Nitto Terragrapplers, Limited running boards taken off. sold
been out the game for a couple years now, i miss my 4runner
09-23-2020, 03:52 PM
#379
Me, bored at work this morning: Is that a Supra thread in this guys sig? Guess I'll check it out.
Me, 26 pages later:
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
10-08-2020, 06:14 PM
#380
Moderator
Real Name: James
Moderator
Real Name: James
Originally Posted by Silver Supra
She's coming along VERY nicely!! Awesome job.
Glad you're still hanging in there lol... thanks man. Everyone's out at SIV right now, wish I was there!
Aww man you sold the 4R? This thing needed so much work... lol... thanks for dropping by and checking in. I'm happy to hear you like it! It's been so long in the process that I just wish I could drive it already.
Me, 26 pages later:
LOL! Do we have the same job?
First of all, THANK YOU! It's a new sig pic, sounds like it works
You must've spent a while! Holy cow am I glad to be past all of that bodywork!
Thanks for checking it out and I hope you'll be around when it finally sees action again!
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
10-08-2020, 06:43 PM
#381
Moderator
Real Name: James
Moderator
Real Name: James
I got through installing the alarm system, which was a huge task. I don't plan to post much detail on that, for obvious reasons, but it is a top of the line system and has numerous backups. I took my time making sure it would be stealthy and as difficult as possible. All the sensors, bells, and whistles.
With the alarm install finished, the new dashboard went into its new home.
After that, I went into testing various electronic functions. I had make one mistake in the alarm install, the parking light polarity, since I had wired the parking lights to the steering column and not in the driver kick panel.
If you wire the parking lights to the kick panel, it needs 12V+, but at the column, it's a switched ground.
Upon initial testing of the alarm, the 12V+ signal that went to the steering column parking light wire had been incorrect, and the very first thing to be shorted in the circuit is the integration relay. The integration relay controls all of the courtesy lights, parking lights, etc. It's located BEHIND the driver's junction block, which was a total pain in the ass to get to.
Got a replacement relay from eBay and corrected the polarity, now it's all functioning as intended.
With the dash in place, the new panels came out of the boxes for parts swapping.
First up was the center panel. Swapped over the clock and cigarette lighter. Removed the HVAC module.
New traction button covers. The far right cover was discontinued, so had to reuse the old one.
The next thing was the gauge cluster. This car did not go through this amount of work to be left with an auto tach with faded ugly needles.
I gathered up all of the new HVAC buttons and knobs, the HVAC unit, and the gauge cluster, then sent them to Stu Hagen.
I asked for a 10K TRD Tach with the needle in the proper 6-o'clock position, a 200mph speedo, coolant temp with readout, and white backlighting.
The left turn signal filter on the cluster was damaged. Stu polished it out.
The HVAC received all new buttons and knobs, as well as a set of white LED's. The temp knob has a red and blue LED's for hot and cold.
10-08-2020, 06:57 PM
#382
Moderator
Real Name: James
Moderator
Real Name: James
There are a ton of people who swear by Do-Luck and their floor bars. I got a set through RHDJapan along with a rear cross bar. May not use the cross bar as I would really prefer to leave the carpet intact. Might go with a harness bar from SP instead, since there's no carpet modification necessary.
Seriously, can you imagine how hard/expensive it'd be to get a new carpet for one of these? Most of the examples of Do-Luck cross bar installation that I've seen online basically obliterated the carpet. Who wants to see that?
Floor bars installed:
From inside the cabin:
Original carpet all cleaned up
Cluster shining bright with new "glass"
The OEM seats are worn, but have really nice plastics. They're absolutely worth keeping and maybe reupholstering.
I don't have plans to use them right now, perhaps I'll add them to the future SC build pile, along with the old suspension, brakes, etc.
In their place will be a beautiful set of black Italian leather Sparco Milano Prestige II's. They have carbon-style plastics which look pretty nice. These are well renowned by the likes Peter Kop (the original owner of them), Ken Henderson, and many others. The Sparco brackets are known to be crap, so these are going in with Titan brackets.
I got the seats from a local Supra owner, Martin, who has a beautiful DJG 97. His single turbo setup is quite inspiring, so I'm just now getting into the research required for a proper single turbo swap.
Here's a few pics of his beautiful 97:
I really like the 1UP catch can setup with braided lines.
11-19-2020, 01:48 PM
#383
Real Name: Christian
Good stuff, as always! Martin's C10 doesn't look too shabby either.
11-19-2020, 04:32 PM
#384
Moderator
Real Name: James
Moderator
Real Name: James
Thanks cblock!
Martin's got quite a selection at his house. Raptor, Terminator Cobra, C10, 5th gen 4Runner, and the Supra. Regarding the C10, it is one of the cleanest actually-driven 67-72 C10's I've ever seen. Too many become trailer queens. I wish I had a 4 car garage like he does.
11-30-2020, 02:34 AM
#385
Moderator
Real Name: James
Moderator
Real Name: James
While sifting through some of the previous owner records, I found a card for Focus Auto Sales in Garden Grove. Google shows that location had closed years ago and is now an empty lot.
Using the Wayback Machine website and a little google-fu, seems like the dealership sold primarily JDM cars, and lots of Supras. The Carfax report showed that a dealer got hold of the car in late October of 2005, with the most recent previous owner buying it from them in February 2006.
Historical aerial maps of Focus Auto Sales from Google Earth Pro came up with this, taken January 2006. Seeing as there is only one car on the lot that’s white with a carbon fiber hood, I’ll bet that’s it right up in the forefront.
I wish someone could tell me more about the history of this car… Any info or photos that might still exist from the dealership around that era would be incredible! Is Jacko Luong (@supraskyline) still around SF?
11-30-2020, 02:36 AM
#386
Moderator
Real Name: James
Moderator
Real Name: James
Onto another round of OEM parts.
- All new front wheel well liners and engine bay covers (left, right, and lower) as well as their associated hardware
- Front bumper lip retainers
- AC hard lines
- Hood insulator
- Windshield dam kit
- Windshield wiper cowl
- Carpet clips
- Shifter surround bolts
- Radio bracket bolts (to car and to radio)
- Wiper fluid reservoir upper assembly 85301-14010
TRD boxes are graphite TRD pro wheels for my 4Runner.
Since the dash is coming together, the plan is to upgrade the head unit to a double-din Kenwood DNX997XR, then use Stu Hagen’s method of using the OEM audio amp to power the OEM sub.
The old Alpine CDA-9884 that was in there before has been installed just for the meantime.
The Blitz turbo timer is definite old-school cool, and fits nicely below a single-din radio, but there’d be nowhere to mount it with a double-din. It’d have to go into the glove box since there would be no cutting involved to get it in there. The turbo timer setup is all subject to change once an engine management upgrade happens (leaning towards a plug and play ProEFI with conversion harness).
Trying to get a glimpse of a completed dashboard
Radio antenna coming up for the first time in 2 years
11-30-2020, 02:37 AM
#388
Moderator
Real Name: James
Moderator
Real Name: James
Original glovebox cleaned and treated with 303 protectant
New spring stopper as the old one was broken
Glovebox and airbag install complete
Rear carpet clips (cargo area carpet where it attaches to back seat)
I went at the Sparco Milano Prestige II seats with Meguiar’s Leather Cleaner & Conditioner and a microfiber cloth.
Quick before and after.
11-30-2020, 10:48 PM
#389
Real Name: Doug
Real Name: Doug
Wow
James, I've been watching your threads for YEARS! I loved your transformation of your 99' 4R, then I was gobsmacked when I stumbled upon your thread on that incredible story of your 87' 4R! Then this 94' Supra!!! I absolutely love this beauty!!!!
I have worked on several vehicles with my son now for a couple of years, starting with his first car, 2003 Mits Eclipse, then his 1990 Civic SI (my Wife described it as a "dog in a coma", it sat for a year after a fairly significant rear ender accident) and now he has been converted to Toyota--- he was lucky in finding a 94 Celica, 3 weeks ago, as his next project! Personally, I do generally prefer his Celica over my 2002 Celica. Up here in BC, Canada, his objective is to restore it to the point where he can get "collector plates" meaning a complete OEM restoration.
Major respect to you for your incredible commitment, time and efforts in the work you do, and the effort it takes to share these experiences. THANK YOU
I'll share the latest pic of my beloved 4R and my son's Celica!!
1998 SR5 3.4L V6 Auto... Pretty much bone stock...aside from the Tundra brakes, OME880 and OME906's in back all with Rancho 9000XL adjustable shocks ... "Livin' the dream in the Canadian Okanagan!"
Electronics/Telecommunications Engineering Technologist
01-05-2021, 01:40 AM
#390
Real Name: Jeff
Real Name: Jeff
Well, somehow I got unsubscribed from this thread several months ago after following it since pretty much day 1. I can't say I'm too angry about it since there were so many great posts with all the work you've done! Seriously James, Well Done!
This car is amazing, and is only going to get more so. Keep up the fantastic work!
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
