Old 08-24-2022, 05:35 PM #1
senordan senordan is offline
senordan is on a distinguished road
Toyota Camry best way to fix a 1/4" hole on a door sill
I purchased a used Camry from Carmax and found a 1/4" hole plugged up. Never noticed it on initial inspection as it was professionally "covered up" with a rubber plug. There was no rust noticed on the inspection as well.
So now I have this 1/4" hole on the right pass door sill. Thoughts on getting this repaired? I can already see the paint bubbling up. Weld? Bondo? Sue Carmax?
Toyota Camry best way to fix a 1/4" hole on a door sill-img_6368-jpg  Toyota Camry best way to fix a 1/4" hole on a door sill-img_6365-jpg  Toyota Camry best way to fix a 1/4" hole on a door sill-img_6361-jpg
senordan is offline   Reply With QuoteReply With Quote
Old 08-28-2022, 05:17 AM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
That hole looks to have been drilled, it could have been done to use a tool to remove a small dent by a "Paintless Dent Repair" tech, if not I'm not sure why is was drilled, it's definitely not a rust hole.
I would use a rust converter on it then either fill it with your choice of body filler then primer and touchup paint, or just touchup paint after the rust converter and then put the rubber plug back in, check it about every 6 months to a year to see if the rust converter has stopped it from further rusting and reapply if needed, etc., etc.
2004 Limited V8
1/4 , camry , carmax , hole , inspection
2013 Toyota Camry, Prius V Get "Poor" Crash Rating in New Test Thai General Discussions 1 12-20-2012 05:30 PM
Got problems with door sill.. Lowriderman234 3rd gen T4Rs 5 05-13-2011 05:58 AM
Door Sill mod - $30 weifert 4th Gen T4Rs 9 12-20-2010 05:36 PM
Door Sill weifert 4th Gen T4Rs 3 11-14-2010 12:33 PM
Door sill clips jmrwd3 3rd gen T4Rs 1 01-31-2007 01:29 AM
