05-09-2019, 12:43 AM
#16
Real Name: Justin
Real Name: Justin
Using a stud welder and slide hammer to pull out the dented cowl:
YouTube
2000 IJM Highlander RR Diff Lock
V6 4WD Auto
Second owner, 300,000+ miles
Grand adventures ahead!
05-15-2019, 05:09 AM
#17
Good
Good one
05-15-2019, 08:48 AM
#18
Real Name: Jeremy
Real Name: Jeremy
YouTube
nice work..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
07-22-2019, 05:34 PM
#19
Real Name: Justin
Real Name: Justin
V6 4WD Auto
08-14-2019, 01:50 AM
#20
Real Name: Justin
Real Name: Justin
Engine is out!
YouTube
V6 4WD Auto
09-08-2019, 12:13 PM
#21
Real Name: Justin
Real Name: Justin
Making some progress. After pulling the engine we removed the wiring and dash, pressure washed the engine bay, then removed everything else on the front end. 27 years of oil and grease had to be cleaned up. Welded up some steel plate for the clutch cable entrance that was cracked and partly missing. It's very solid now. Also removed the rear end and fuel tank to get that all cleaned up. Scraped and pressure washed the underside of the car as well. A prior failed pinion seal had made quite a mess back there.
At this point the engine bay is in primer. Need to finish up the rest of the body work (bumpers, block the hood, address some dings) and get the whole car in primer and blocked. Hoping to have it in paint in the next few weeks before the weather cools down too much.
Once it is painted, the rest is just cleaning up/purchasing parts and re-assembly.
Missing bits of the firewall from PO using the wrong bell housing and clutch fork. Way too much pressure here.
Bought the world's smallest welder and got some work done
Not pretty but solid. The rough areas that you can see are seam sealer.
K-member out
Cleaned, primed and slid back under the car
Engine bay primed
Fuel tank and rear end pressure washed
This was nasty before! Hasn't been this clean since 1992.
Garage buddy, one of many helpers in my house.
Won't be long 'til paint. More to come.
V6 4WD Auto
Reason: fix links to pics
09-15-2019, 11:22 PM
#22
Real Name: Justin
Real Name: Justin
I bought all of the paint for the car and got a few more parts in primer (front and rear bumper covers and the spoiler.) The rear bumper cover didn't need much work but the front took some time. It is original to the car, still has the VIN sticker, and as far as I can gather has about 348,000 miles on it. It had several chips, scrapes and gouges, and had been rattle canned black and white at some point. I spent the better part of Saturday cleaning, filling, sanding, trying to repair it as best I could. Still not perfect but looking much better now in primer. Inching closer to paint...
This is from a few months ago before tear down began. Lots of rattle can on the front of the car.
After several hours...
Looking better. Need to address a few things and block it before paint.
V6 4WD Auto
09-27-2019, 10:38 AM
#23
Real Name: Justin
Real Name: Justin
V6 4WD Auto
10-02-2019, 11:44 AM
#24
Real Name: Justin
Real Name: Justin
Thank goodness for cut and buff! As stated previously, much of the clear didn't go down so well due mostly to lack of skill, insufficient CFM, spraying in a garage, phase of the moon, etc....
Luckily wetsanding and polishing works and it looks like I will be able to salvage the paint job.
I loosely mounted up the hood and bumpers so they were out of the way and didn't get knocked over in the garage. Nice to have the area cleaned up a bit after being in full body shop mode. I'll deal with panel gaps when I'm ready to bolt things on for good.
So yeah...some of the clear not looking too hot. See list of excuses above...
After wetsanding and polishing. Now this I can live with, even if it is a bit wavy in places.
50/50 shot, fender to hood
For those wondering, I am doing 1500 grit wet, 2000 grit wet, 3000 grit wet, then polishing compound on a foam pad with a rotary polisher, followed by swirl remover on a lighter foam pad. At this point the plan is to go panel by panel and try to get the whole car looking good in clear.
Justin
V6 4WD Auto
10-02-2019, 11:52 AM
#25
Great job! Love the 50/50 shot
11-07-2019, 05:50 PM
#26
Real Name: Justin
Real Name: Justin
Still at it. I had a mobile painter come out and do a bit of a re-spray focusing mostly on the top of the car where I had a bunch of fisheyes that I had to sand down. He got that part of it looking better. I then spent about 20 hours over two days wet sanding and polishing to cut down some of the orange peel, etc. Darn near sanded my fingerprints off! Still need to do a final polish but I will likely wait for warmer weather to do that. Painted and attached the side moldings and front spats. Cleaned and painted the rear end, front control arms and spindles.
Starting some re-assembly now. I went with Power Stop 13 inch brakes for a 2003 Cobra since I already had SN95 spindles. I also ordered some Cobra decals from ebay. They're a little cheesy but whatever, the powder coating on the calipers looks great and it's a nice functional upgrade over stock. Using KYB shocks and struts, Eibach springs, and UPR rear control arms. Got a bunch of stuff from Prothane for the front as well. I painted one wheel a gunmetal color as a test. I think we'll run that for a while.
The rear end will get new axle bearings and seals and I installed new Ford bushings as well.
Starting to come together a bit. I am hoping to have the car back on 4 wheels by the end of the week.
V6 4WD Auto
01-06-2020, 12:22 PM
#27
Real Name: Justin
Real Name: Justin
Still working on the car and slowly making progress. The garage isn’t quite as inviting during winter but I have a small heater that helps a bit. At this point the suspension is done, wheels are on, fuel tank is in, and much of the engine bay is in place. I will have engine bay wiring done soon and dash wiring soon after that.
I figured out that the engine that came with the car is a 1989 block so it has forged pistons. I will do new bearings, rings, gaskets, and get it cleaned up and painted. Then I‘ll move over the timing cover and accessories from the 93 engine, while adding the 130amp alternator. With a fresh rebuild and the basic HCI upgrades it should be a nice runner.
I found a NOS heater core for sale locally and it sure was easy to install with the HVAC unit on a table. ;) Still need to make some brackets for the G37S seats but now that I know the seats fit in the car, the brackets shouldn’t be too complicated.
My goal is to have the engine done and installed in the next few weeks. I want to be cruising this summer.
I made a couple of quick update videos. Just remember what we started with!
Part 12
YouTube
Part 13
YouTube
V6 4WD Auto
01-10-2020, 02:59 AM
#28
Is it just me who is excited for the outcome?
I feel like there's so much work that is need to be done before this car run smooth again. I can see progress from all the photos that you have attached on every update.
01-10-2020, 03:01 AM
#29
Is it just me who is excited about the outcome?
I feel like there's so much work that is needed to be done before this car runs smoothly again. I can see progress from all the photos that you have attached to every update.
01-16-2020, 08:09 AM
#30
Nice work
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
