Old 08-27-2019, 12:52 AM #1
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
2005 Sequoia AC issues
So my wife has an 05 sequoia that we've had for about a year. The AC works okay up until the ambient temperature is about 105 degrees, which is a problem in the desert southwest because it's over 105 every day for several months a year. We had it serviced last year, but they said everything was fine (I'll see if I can find the paperwork later). I can't remember exactly what they did but oh well.
It seems to work better if you are spraying the condenser with water (noticed at the carwash).
So first off I cleaned the condenser, it had/has some bug guts but nothing that really looks like it is restricting flow. Then I also sprayed the evaporator coil as best I could throught the opening for the resistor.
That didn't make a huge difference so I got a set of loaner gauges from autozone and I saw this.
2019-08-26_09-37-55 by Jeff Burt, on Flickr
So almost 70 low side and a little over 400 high side and outside air temp was 104 with 40% humidity (this is the reason I'm messing with it) and the sight glass is cloudy. My first thought is that the system is overfilled. I could bleed off some of the pressure, or have it sucked out, but my concern is that I've seen some things that say the expansion valve could also be the culprit.
I've thought about removing some refrigerant, and if that doesn't work then then evacuating the system and replacing the drier and expansion valve, but I thought I'd ask around first and see if anyone had any recommendations.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
expansion , sequoia , thought , valve , year
2005 Sequoia Stalls after cornering (solved) xcmountain80 All Other Vehicles 7 04-05-2020 07:40 PM
2005 Sequoia Cranks but won’t start xcmountain80 All Other Vehicles 2 01-09-2019 10:11 PM
2005-2006 Toyota Tundra, Sequoia 4.7 INJEN intake krans For Sale: Non-T4R Items 0 02-15-2017 12:31 PM
Possible issues on a 2005 4R from NY? grave 4th Gen T4Rs 6 08-26-2016 08:46 PM
2005 Sequoia skid plate on 2005 4Runner?? Florida Sport 4th Gen T4Rs 2 03-26-2014 02:58 PM
