The red 1990 2-door 4Runner is in the midst of a 5-speed manual swap.
The original auto transmission used a VSS with a cable to speedometer. The R150F being used for the swap came from a 1993 model with electronic VSS.
I just happened to have a newer SR5 cluster to swap into the 4Runner, and all it will take is to wire in the electronic VSS (3 wires). I also disassembled the odometer to match the mileage, so the mileage reading is still 100% accurate.
The old cable driven cluster was now available to be swapped into the pickup truck, which is an 89 and uses a cable.
New oil pressure sending unit
Tachometer adjusted with ohm meter to match 4-cyl
Installed 4Runner speaker boxes while it was apart.
Very nice to finally have an SR5 cluster.
The voltage, oil pressure, and tachometer are great, one overlooked feature is the trip meter. So strange not having one in the base cluster.
