09-17-2019, 05:13 PM
Moderator
Real Name: James
Moderator
Real Name: James
COB's '89 Pickup 2WD
Toyota #5 in the stable! I have wanted a nice little pickup for the utility aspect.
1989 Toyota Pickup DLX 2WD
My personal vehicles/projects:
99 4Runner - 2wd to 4wd conversion, 5-speed swap, supercharged
87 4Runner - 5-speed swap, CT-26 turbo, rebuilt 22R-TE
94 Supra Turbo - Undergoing restoration, lucky find
89 Supra Turbo - White on White on White on White
My '94 Supra turbo restoration was underway and I needed to transport the subframes to and from work.
My friend just happened to get a little red Toyota pickup that I immediately fell in love with, and decided to get one of my own.
Found this 1989 model, 22R-E, 5spd, 205k on the odo. Paid $2,100.
Seeing the truck for the first time at the seller's house.
Driving through scenic Long Beach/San Pedro on the route home.
The pickups side by side
Someone wired up an aftermarket radio back in the 1980's! Look how official this looks... serial numbers for this piece of junk! Haha.
Came complete with service records dating all the way back to day 1.
Together, the little worker Toyotas gathered parts for Queen Toyota waiting at home.
Unloaded at home via the trusty engine hoist
I love cruising around in the little pickup, which has been nicknamed the "putt putt pickup."
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
09-17-2019, 05:33 PM
Moderator
Real Name: James
Moderator
Real Name: James
So I have a sweet pickup bed trailer, but in all honesty, it sucks to use because it's too tall. It's really only meant as an off road trailer, for which it does well.
This pickup is so enormously useful in several ways... the most obvious is the bed!
Loaded up with a MKIV Supra rear subframe and 4 19" BMW wheels.
Smogged with flying colors.
Then came the little things. The little sail panel behind the mirror was gone. Got one from my friend who happened to have some extra parts laying around.
Shackle bushings
*Beavis Voice* FIRE
Rear shocks, Monroe's (cheap from Rockauto)
Both Toyotas here could have been purchased brand new on the same day...
Both are:
1989
Toyota
White
Blue interior
Manual 5 speed
RWD
Inline engines
09-17-2019, 05:50 PM
Moderator
Real Name: James
Moderator
Real Name: James
I spy Toyotas...
Scored a nice set of matching blue buckets and center console.
Used transmission with good bearings, $300. Came with an Aisin clutch kit that has about 70% left in it.
Also got the roof map light assembly which was a great upgrade over the little tiny DLX light.
4Runner dash pocket.
Got the bench seat out for the swap.
09-17-2019, 06:41 PM
Moderator
Real Name: James
Moderator
Real Name: James
Scored a couple center caps, so far just for the front wheels.
Also found a Toyota bed liner from a 1994 Pickup.
In my opinion, this helps complete the look... though I still need to locate the tail gate section.
I have also replaced the blower motor switch.
While I was in there, I noticed there's a rather primitive cigarette lighter setup with no lamp, and the ashtray is devoid of a lamp as well.
I wired in a 2nd gen 4Runner cigarette lighter with lamp, plus swapped the ashtray metal support with one that has a lamp hole. Both lamps are now functioning beautifully. While I was at it, I pulled the ancient radio and installed a double-din Toyota radio from a 2002 4Runner, including the factory amp.
I found out that you can buy an interface adapter for these radios, as they feature a 5+7 pin CD changer plug.
I wired in a Milllenia MIL-BTREC bluetooth receiver and plugged it into the AUX cable with a simple RCA to 3.5mm adapter. I'm enjoying bluetooth audio straight from my phone, no wires or cables!
To make sure everything's up to par, I updated the antenna with a new unit and installed some new speakers.
Rockford Fosgate 4" speakers, only $35 online. They sound awesome!
I dig the front bumper and grille setup on the 1992-95 pickups, so I've begun converting the front end to that style. I also installed a set of Eagle Eyes corner lamps and Autopal conversion headlamps that use a bulb instead of a full sealed beam unit. Currently using NAPA Brilliant Night Vision bulbs that are tremendously better than the regular sealed beams. I've also got an OE lower valance from the 92+ style that will go on after I paint it and the bumper. More to come later on that.
09-17-2019, 11:53 PM
I think you need a bigger garage for your toys.
2018 Toyota Tacoma
2010 Toyota 4runner TE - Sold
2002 Toyota 4runner - Sold
2000 Toyota 4runner - rolled
1996 Toyota 4runner - sold a long time ago in a galaxy far far away.
09-18-2019, 11:27 AM
You are really making me miss my '99 Tacoma 4x4. There is nothing more practical than a pickup.
2012 SR5 4x4 Magnetic Gray, Third Row, Cooper Discoverer AT3 LT 265/70/17 load range C, Bilstein 5100s at 0.85, Husky Weather Beaters and Mud Flaps, Front Air Dam Removed, Canvasback Cargo Liners
Former Tacoma Owner https://flic.kr/p/s1m3mS
09-18-2019, 02:27 PM
Originally Posted by ChildrenOfBodom
*Beavis Voice* FIRE
how much did the semi truck full of ES bushings run you? seems like it could be handy, maybe not cost effective but who knows? ;)
lol, the collection is really getting there man, good to see you're still kicking around here! I'm at 5 myself as well, 1st, 3rd and 4th gen 4runners, LX470 and a 2nd gen taco, feels pretty good to have a stable of yotas to choose from when you head out in the AM.....changing cars like most guys do shoes.
keep up the good work brother and hope all is well in life!
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
01-16-2022, 03:27 AM
Moderator
Real Name: James
Moderator
Real Name: James
Hey smallfry, bane, and jason, hope you guys are doing well after all this crazy stuff going on in the world.
Should probably get to updating this thread after 3ish years.
Bosch distributor cap and rotor
NGK plugs and wires
Spark plug boots
New high pressure PS line
Monroe shocks and Energy Suspension shock bushings
Tailgate liner found
OEM to match the bed liner
Roof rack for the 4Runner
10-01-2022, 10:24 AM
Real Name: Charlie
Real Name: Charlie
That's one sweet little truck!!
Originally Posted by STX4Runner
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
10-16-2022, 06:08 AM
Moderator
Real Name: James
Moderator
Real Name: James
Cleaned the wheels up for the first time, they have a million crevices. A drill brush attachment and some simple green did the trick.
The other white 89 Toyota peeking out from behind, and two classic red 2-doors.
Left bedside is fading quickly, but that's the cleanest these wheels have been yet.
The truck started having fuel pressure issues with a full tank, it got worse until the truck refused to start at all.
The fuel pump had given up. The 1989 trucks use a large fuel pump with two threaded terminals for positive and negative. These are still available, but don't come with any new stuff like hoses, clamps, filter sock, etc.
I opted for a 1992 style pump, which is smaller in diameter, but is still powerful enough to replace the larger pump. It uses a standardized two prong fuel pump plug.
New DENSO pump from RockAuto.
Truck up on 4 stands with enough clearance to drop the fuel tank
Look at all that space
If the truck was a 4x4... this would be about the height
Old pump
New pump does not fit in the larger pump hanger, but a hose clamp will do the job. New clamps and hose. Cut the old eye terminals off the wires and installed a new wire connector.
Time to get the tank back into its home, with the help of a Harbor Freight transmission jack
Quick oil change while we're at it
And right back to work!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
1st Gen Pickup Doors
Defiance |
For Sale: Non-T4R Items |
0 |
09-22-2015 10:18 PM |
1st gen pickup
29yota |
Classic T4Rs |
3 |
04-03-2015 03:27 PM |
4R Pickup
Park |
3rd gen T4Rs |
3 |
11-16-2012 05:19 PM |
82 4x4 pickup
Kel Varnsen |
Off Topic |
1 |
05-28-2012 06:45 PM |
BMW Z4 vs pickup
pokerface |
Off Topic |
1 |
08-13-2006 09:59 PM |
