Old 09-23-2019, 08:57 AM #1
gx470 gx470 is offline
gx470 is on a distinguished road
03' sequoia new steering rack problem?
I have an 03’ sequoia and mechanic just replaced the rack and pinion system. There is a bushing and clamp that holds the rack in on the passenger side, the new rack is moving inside of that about a 1/4-1/12” causing a creaking sound when turning the steering wheel from the 10-2 position. Is it normal for the rack to move and this just needs grease on the new bushing or is the bushing supposed to lock it completely into place?
gx470 is offline   Reply With QuoteReply With Quote
Old 09-23-2019, 01:59 PM #2
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
The rack needs to be solidly mounted and should not move. It is definitely not a good thing if you are seeing this type of play. The steering rack bushings on basically all Sequoias and Tundras are well known for this problem.
Good news is that there's a company out there that makes new bushings for these out of polyurethane, which is a material that's far stiffer than rubber. These bushings are meant to prevent the rack from being able to move side to side like that.
Energy Suspension part # 8.10104
Just read the reviews on this page:
8.10104 | Rack and Pinion Bushings | 00-06 Tundra 01-07 Sequoia
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 02:03 PM #3
thank you, my mechanic replaced the bushing and it's 99.5% better, there is a faint sound after sitting and when I turn it side to side before moving. Mechanic said it's normal to move some. If that's not true, can you show me a pic of the exact mounting bolt to try to tighten? Thanks
bushing , rack , sequoia , steering , wheel
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
Sequoia rear window problem irv6744 All Other Vehicles 2 05-03-2007 02:40 AM
