Old 01-24-2020, 02:15 PM #1
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Dobinsons Tundra Options (1st & 2nd Gen)
Hey Guys. I've had quite a few Tacoma guys recently ask about what options Dobinsons have for the Tundra (old and new), so I'm going to break it down here with each part so that it's all easier to find for anyone in the future.
Tundra 2000-2006
Front Coils
C59-302 - 2" Lift w/stock weight, 395/395mm free height, 586LB rate (requires new upper coil isolator)
C59-314 - 2.5" Lift w/bumper or winch, 405/405mm free height, 586LB rate (requires new upper coil isolator)
C59-344 - 2" Lift w/bumper & winch, 370/370mm free height, 650LB rate (uses OE upper coil isolator) - Same as 1st Gen Sequoia front coils
Front Struts
GS59-222 - Twin Tube Nitrogas struts, 2" body, 465mm ext, 365mm comp
Rear Shocks
GS59-940 - Twin Tube Nitrogas shocks, 2" body, 614mm ext, 361mm comp
Rear Leaf Springs
Sorry, we don't offer a replacement leaf pack or add-a-leafs for this generation
Rear Quick Ride Kit (blocks & u-bolts)
QR59-551K - Quick Ride Kit, 2 lift blocks with caster correction built in and correct length u-bolts
Tundra 2007-2020
Front Coils
C59-610 - V8 Models - 2.25" Stock Weight, 2.0" w/bumper and winch, 410/410mm free height, 737LB rate
C59-578 - V8 Models - 3" Comfort Ride with stock weight only, 460/460mm free height, 662LB rate. This height requires UCA's.
Front Struts
GS59-710 - Twin Tube Nitrogas struts, 2" body, newer extended length to suit 0-3" lift heights
Front Diff Drop Kit
DD59-530K - For 3" front lift, reduces angle on CV joints
Rear Shocks
GS59-711 - Twin Tube Nitrogas shocks, 2" body, suits 0-2.5" lift heights
Rear Leaf Springs
L59-120-R – 4 + 2 Leaves, Raised Height (55mm, 2.25″ Lift) Heavy Duty for stock to medium loads
L59-121-R – 5 + 2 Leaves, Raised Height (55mm, 2.25″ Lift) Heavy Duty for heavy constant loads (300LBS+)
Rear Quick Ride Kit (blocks & u-bolts), instead of leaf packs
Rear U-bolts
UB59-437K - Sold as 2 pairs, enough for 1 truck
Rear Greasable pins/bolts
SP59-060 - Sold in pairs, designed for fixed end of spring but can be used on shackle end also to add easy greasing
Leaf Spring Bush Kit
PB59-1102K - Contains all required 6 bushings for both ends of the leaf springs plus the shackle hanger
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 02:16 PM #2
Crikeymike's Avatar
Crikeymike's Avatar
Tundra with 3" front comfort coils, 2" quick ride rear and SPC upper control arms
Dobinsons Tundra Options (1st & 2nd Gen)-tundra-3infront-2inquickriderear-jpg
Old 01-24-2020, 02:17 PM #3
Crikeymike's Avatar
Crikeymike's Avatar
Both of these have the same 2" front and rear suspension with full leaf packs.
Dobinsons Tundra Options (1st & 2nd Gen)-tundra-full-2inch-lift-jpg  Dobinsons Tundra Options (1st & 2nd Gen)-tundra-full-2inch-lift-b-jpg  Dobinsons Tundra Options (1st & 2nd Gen)-tundra-full-2inch-lift-c-jpg  Dobinsons Tundra Options (1st & 2nd Gen)-tundra-full-2inch-lift-d-jpg  Dobinsons Tundra Options (1st & 2nd Gen)-tundra-front-strut-assembly-jpg
Old 01-30-2020, 12:02 PM #4
Crikeymike's Avatar
Crikeymike's Avatar
Hey Guys
For the month of February 2020, Dobinsons is running a free Air Compressor deal with a full suspension kit purchase. Here are the details.
Purchase a full Dobinsons suspension with twin tube struts and shocks, and receive an AC80-3808 Air Compressor free with your order. $145 value
Dobinsons 4x4 Portable 12V High Output Air Compressor Kit with Bag, Hose and Gauge (AC80-3808) | Exit Offroad
Purchase a full Dobinsons suspension with new Monotube (resi or non-resi IMS) struts and shocks, and receive an AC80-3846 Dobinsons Zenith Air Compressor. $325 value
Dobinsons 4x4 Zenith Portable 12V High Output Air Compressor Kit with Bag, Hose and Gauge (AC80-3846) | Exit Offroad
The free item will automatically be added to your order, no coupons or anything required.
Regarding the IMS (non-resi) and MRA (3-way adjustabl w/resi), ETA's are variable on those products, so your order won't ship right away, but you'll still get the deal. You will be emailed an ETA when the order is placed, or can ask up front.
front , height , leaf , lift , rear
Dobinsons 5th Gen T4R Suspension options - from Exit Offroad Crikeymike 5th gen T4Rs 3364 04-16-2024 10:49 AM
Dobinsons Suspension - 4th Gen Options Crikeymike 4th Gen T4Rs 1229 04-07-2024 10:03 PM
