Old 10-05-2020, 11:03 AM #31
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is just really nice MStudt is just really nice MStudt is just really nice MStudt is just really nice
official vendor
MStudt's Avatar
Over the weekend I was able to install the lvp flooring in the cargo area, and add a little aluminum j-trim & angle to help finish it off a little. The j-trim really added a clean look around the door opening, and the angle helped to close in the side some.
In addition to that I started to assemble a small storage area that'll be installed between the bed, and the door. This will house our Dometic toilet, and allow for a little bit of additional storage.
Lastly, I started prepping the wood for the ceiling. I went with blue pine or beetle kill pine. I love the way this wood looks, but it's going to take quite a bit of prep work before I can hang the pieces. The material is 5/8", 5-1/2" in width, and tongue & groove. I'm currently in the process of cleaning out all the beetle channels, and filling those with black hot melt wood filler. Once the filling is complete I'll have to finish sand everything before sealing the wood. I'll be using a shellac on the side facing the metal roof, and a poly on the visible face. Installation will consist of rivet nuts in the rood ribs, and stainless black oxide FHCS recessed into the wood.
MStudt is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 10:09 PM #32
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
I designed the kitchen cabinet earlier this week in a bit of a rush, but it turned out pretty good. The main back panel is 18mm ply with black laminate on the front and phenolic backer on the back. The dividers and cross braces are all 12mm raw ply. The top if going to be butcher block with a bottom mount sink, and a 2-burner propane cooktop. The narrow side on the right will be full of drawers, and the left will have a couple of doors to access the plumbing.
Old 10-26-2020, 03:41 PM #33
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Well, looks like I've forgotten to post for a bit. I don't have anything complete that I've started on, but forward progress is still progress.
The toilet hider and side storage area are just about complete. I have the floor pan drawing for the toilet but need to have it cut, bent, and powder coated. Once I have that back I can get it mounted with some Accuride locking draw slides. Last thing will be making a door to the cover the front, and figure out some kind of a wheel system to support the front when it's supporting weight.
The cooler storage is in the same boat. I have the floor pan drawn but need to have it cut, bend, and powder coated so I can install it. I also need to find a solution for the doors on this, but that shouldn't be very difficult.
The shelf and counter only need to be sanded, and sealed. I ended up using butcher block for both, and pick them up at my local Home Depot. The shelf will end up with some kind of a small lip on it, and I'm also going to cut a thin piece to act as a back splash.
Flooring is also installed.
Old 10-26-2020, 04:19 PM #34
RedSled's Avatar
RedSled RedSled is offline
RedSled will become famous soon enough RedSled will become famous soon enough
RedSled's Avatar
Great stuff Mike, you got skills man.
2017 Silver SR5 Premium
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 06:01 PM #35
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 will become famous soon enough cblock406 will become famous soon enough
cblock406's Avatar
Wow this is super cool, definitely got some skills.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 11:00 AM #36
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
The ceiling is just about finished. I only need to install the two filler pieces on the sides, and replace the out of color pieces in the middle. Overall I'm very happy with how this turned out.
Old 11-16-2020, 11:57 AM #37
RedSled's Avatar
RedSled's Avatar
Was that beetle kill dried? Just curious.
Old 11-16-2020, 03:52 PM #38
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Yes it was.
Mike
Old 11-16-2020, 04:02 PM #39
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 is a name known to all momo.75 is a name known to all momo.75 is a name known to all momo.75 is a name known to all momo.75 is a name known to all momo.75 is a name known to all
Registered User
momo.75's Avatar
Real Name: Morris
that is looking so badass
momo.75 is offline   Reply With QuoteReply With Quote
box , build , couple , doors , van
Dinardy Expo Build Dinardy 3rd gen T4Rs 7 05-27-2015 05:52 PM
2013 Lucas Oil Off-Road Expo Broker So Cal 20 10-07-2013 01:10 AM
Overland Expo, Flagstaff, AZ May 17-19, 2013 phillyd2 5th gen T4Rs 44 05-19-2013 05:41 PM
Overland Expo 2013 Stockwell45 Off Topic 2 05-07-2013 11:18 PM
2013 Chevy Trailblazer Bigmikelakers All Other Vehicles 5 11-15-2011 12:37 PM
