10-05-2020, 11:03 AM
#31
official vendor
official vendor
Over the weekend I was able to install the lvp flooring in the cargo area, and add a little aluminum j-trim & angle to help finish it off a little. The j-trim really added a clean look around the door opening, and the angle helped to close in the side some.
In addition to that I started to assemble a small storage area that'll be installed between the bed, and the door. This will house our Dometic toilet, and allow for a little bit of additional storage.
Lastly, I started prepping the wood for the ceiling. I went with blue pine or beetle kill pine. I love the way this wood looks, but it's going to take quite a bit of prep work before I can hang the pieces. The material is 5/8", 5-1/2" in width, and tongue & groove. I'm currently in the process of cleaning out all the beetle channels, and filling those with black hot melt wood filler. Once the filling is complete I'll have to finish sand everything before sealing the wood. I'll be using a shellac on the side facing the metal roof, and a poly on the visible face. Installation will consist of rivet nuts in the rood ribs, and stainless black oxide FHCS recessed into the wood.
10-08-2020, 10:09 PM
#32
official vendor
official vendor
I designed the kitchen cabinet earlier this week in a bit of a rush, but it turned out pretty good. The main back panel is 18mm ply with black laminate on the front and phenolic backer on the back. The dividers and cross braces are all 12mm raw ply. The top if going to be butcher block with a bottom mount sink, and a 2-burner propane cooktop. The narrow side on the right will be full of drawers, and the left will have a couple of doors to access the plumbing.
10-26-2020, 03:41 PM
#33
official vendor
official vendor
Well, looks like I've forgotten to post for a bit. I don't have anything complete that I've started on, but forward progress is still progress.
The toilet hider and side storage area are just about complete. I have the floor pan drawing for the toilet but need to have it cut, bent, and powder coated. Once I have that back I can get it mounted with some Accuride locking draw slides. Last thing will be making a door to the cover the front, and figure out some kind of a wheel system to support the front when it's supporting weight.
The cooler storage is in the same boat. I have the floor pan drawn but need to have it cut, bend, and powder coated so I can install it. I also need to find a solution for the doors on this, but that shouldn't be very difficult.
The shelf and counter only need to be sanded, and sealed. I ended up using butcher block for both, and pick them up at my local Home Depot. The shelf will end up with some kind of a small lip on it, and I'm also going to cut a thin piece to act as a back splash.
Flooring is also installed.
10-26-2020, 04:19 PM
#34
Great stuff Mike, you got skills man.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
10-27-2020, 06:01 PM
#35
Real Name: Christian
Wow this is super cool, definitely got some skills.
11-16-2020, 11:00 AM
#36
official vendor
official vendor
The ceiling is just about finished. I only need to install the two filler pieces on the sides, and replace the out of color pieces in the middle. Overall I'm very happy with how this turned out.
11-16-2020, 11:57 AM
#37
Was that beetle kill dried? Just curious.
Vietnam 67-68
11-16-2020, 03:52 PM
#38
official vendor
official vendor
Yes it was.
Mike
11-16-2020, 04:02 PM
#39
Registered User
Real Name: Morris
Registered User
Real Name: Morris
that is looking so badass
12-13-2020, 12:22 AM
#40
Loving this! Looking forward to the finished product.
2020 Midnight Black Metallic 4runner Offroad premium
05-04-2021, 11:18 AM
#41
I will be following this cool build. Always wanted to do something like this!
Cool that you are doing it!
05-04-2021, 06:16 PM
#42
official vendor
official vendor
I need to get some new picture posted since I've been slacking on it.
Mike
05-10-2021, 11:01 PM
#43
official vendor
official vendor
05-10-2021, 11:10 PM
#44
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Man, that is looking awesome!
02-18-2022, 12:19 PM
#45
official vendor
official vendor
