Old 02-18-2022, 02:03 PM #46
momo.75's Avatar
momo.75 momo.75 is offline
Registered User
Real Name: Morris
momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold momo.75 is a splendid one to behold
Registered User
momo.75's Avatar
Real Name: Morris
Originally Posted by MStudt View Post
I've been slacking about posting pictures of the progress, and trips. For the most part the van is complete, and I'm pretty happy with how everything turned out. I still need to build bumpers, and do a little more electrical work.
That is awesome!
momo.75 Build ThreadClick to order T4R.ORG Decals • @urban_overland
momo.75 is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 12:46 PM #47
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
A couple of weeks ago I started on the rear bumper and tire carrier. I'm reducing the overall depth of the rear step by 5" and shortening it on each side by roughly 12". First I removed the old flaking thread plate, spreader and got everything prepped for the new crossmember.
MStudt is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 12:51 PM #48
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Next up was welding in a new 2" x 3" x .120 crossmember with a 2" receiver hitch. The receiver hitch will only be used for hauling our bike and never used for towing anything. So I wasn't overly concerned about the size of the material. I made some side plate reinforcements from 7 ga CRS that ran the length of the dog legs and wrapped around the rear onto the new crossmember. The top plate is a galvanized perforated stair thread that uses carriage bolts run though connector plates.
Old 10-03-2022, 12:58 PM #49
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Over the weekend I was able to start building the swingout tire carrier, and almost finished it. The carrier hinge is a 4xInnovations, and all the tubing for the swingout is 1-3/4" x .120 DOM. I also purchase the tire mounting plate from Ruff Stuff, and the a compression latch from SouthCo going on. Building this also gave me an excuse to use the JD2 vertical bender again.
I still need to design and build a mount for a AT Overland Equipment jerry can holder, and design a mount for a Zarges aluminum case. The aluminum box will serve as a small storage area, and a small work surface when opened.
Old 10-03-2022, 01:55 PM #50
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all rdruss is a name known to all
rdruss's Avatar
Real Name: Ron
Love to watch people who have the skills and tools to fabricate, they can bring their ideas to life! Thank you.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-20-2022, 05:12 PM #51
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
I'm jumping backwards a little since I don't think I ever posted the electrical setup in the rear of the van. We have two 100w solar panels on the roof with a 200Ah hybrid gel battery running everything. We're using a Victron MPPT 75/15 controller, Victron shunt, and Victron Blue Smart Charger. Several Blue Sea breakers, Blue Sea blocks, Blue Sea fuses, Blue Sea fuse panel, and Blue Sea Disconnect. We also have a Victron 1000w power inverter, and will have a Victron converter once we're hooked up to the alternator.
Old 10-25-2022, 05:50 PM #52
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
If you know you know. About to get comfy and warm.
Old 12-19-2022, 12:00 PM #53
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
I've been trying to wrap some things up before departing for our road trip on 12/23 when we head into No-Cal for a week. That means I should be dumping a lot of updates over the next couple days.
First update is small, but pretty significant. I recently purchased some insulated window and fan covers from Tourig. These are a very nice window cover that's super easy to install and use with them being held up by a few magnets. I also have them working on some custom covers for our back windows since no one seems to make anything for those.
Old 12-22-2022, 07:50 PM #54
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
This morning I was able to finish up the rear bumper, and just in time for our upcoming trip tomorrow. The aluminum box was a bit of a last minute idea that'll double as a work center. I'll be able to store some item in this, and have a flat work space if needed.
box , build , couple , doors , van
Dinardy Expo Build Dinardy 3rd gen T4Rs 7 05-27-2015 05:52 PM
2013 Lucas Oil Off-Road Expo Broker So Cal 20 10-07-2013 01:10 AM
Overland Expo, Flagstaff, AZ May 17-19, 2013 phillyd2 5th gen T4Rs 44 05-19-2013 05:41 PM
Overland Expo 2013 Stockwell45 Off Topic 2 05-07-2013 11:18 PM
2013 Chevy Trailblazer Bigmikelakers All Other Vehicles 5 11-15-2011 12:37 PM
