Old 06-28-2018, 09:34 PM #1
Battle Born Offroad Battle Born Offroad is offline
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Enkei RPT1 Offroad Wheels - Enkei is jumping into the Japanese SUV Offroad scence!
Were not sure if anyone else has noticed this, but does it seem like a lot of legendary tuner brands are jumping into the offroad market, particularity Toyota trucks and SUVs? Its great to see classic designs being adapted for offroad use.
Check out these awesome looking Enkei RPT1 Offroad Wheels - Only offered in 16x8 and 6x139.7, a perfect Toyota truck or SUV size! The Enkei RPT1 off-road wheel pays homage to the famous RPF1 wheel, by utilizing a similar twin-six-spoke style, while optimizing the design and sizing to make them perfect for Toyota truck use. Excellent strength analysis and design technology significantly improved the performance of their aluminum wheels by using Enkei's own MAT Flow Form Process with "knurling" to reduce tire slipping.
Enkei Japan Colors
Take advantage of this Enkei factory painted Japan-only color, which have never been introduced by Enkei on United States soil before. Previously only available in the Land of the Rising Sun, Enkei Japan painted each of these wheels alongside all of their other production wheels just for this batch. As an added relief, each color has been thoroughly tested, and approved by Enkei Japan’s strict quality control including rigorous salt spray tests.
What does that mean for you?
It means a tested, trusted, and treated finish unlike any other. Traditionally these wheels would need to be re-coated by a refinishing company to achieve these types of colors. Typically that means powder coating, which not only requires heating the wheel to a temperature that can compromise the integrity of the construction material, but also the finish is not tested or designed to outlast the elements.
Testing
Each of these wheels and its finish has been put through numerous salt spray and stress tests more rigorous than conventional standards. Enkei established its own test standard called “Spec-E,” which is tougher than JWL requirements. Enkei’s Spec-E test setting requires a higher drop point in the impact test and 20% more cycles for the rotary bending fatigue and dynamic radial fatigue tests than JWL standards. The Spec-E represents Enkei’s confidence in its technology and quality of Enkei wheels.
Part Number: 520-680-8400MDG
Bolt Pattern: 6x139.7
Offset: +0mm
Center Bore: 108.5
Finish: Matte Dark Gunmetallic
MAP: $381.72/wheel
Contact us via PM for a T4R members only price.
Battle Born Offroad is offline   Reply With QuoteReply With Quote
Old 06-29-2018, 12:56 AM #2
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Whoa... I have been dreaming of an SBC 17" version of this wheel. I just had my 94 Supra turbo painted the same color as my 4Runner, and it has 18" RPF1's in SBC. Any pictures mounted?
IG: @jimharb | YouTube | '99 Limited 2WD |
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 06-29-2018, 07:34 AM #3
SR5Bart SR5Bart is offline
Real Name: Bart
SR5Bart has a spectacular aura about SR5Bart has a spectacular aura about
Real Name: Bart
Dang too bad there is no 17" option. I would be all over it
18 Trail. Cookie cutter built (SOLD)
14 SR5P (SOLD)
SR5Bart is offline   Reply With QuoteReply With Quote
Old 06-29-2018, 12:20 PM #4
RUNTHAT's Avatar
RUNTHAT RUNTHAT is offline
RUNTHAT is on a distinguished road
RUNTHAT's Avatar
Also available in 18", but yeah, 17s would be cool.
'12 Trail w/KDSS
RUNTHAT is offline   Reply With QuoteReply With Quote
Old 06-29-2018, 12:26 PM #5
ZOMBRNR's Avatar
ZOMBRNR ZOMBRNR is offline
Real Name: Brandon
ZOMBRNR is on a distinguished road
ZOMBRNR's Avatar
Real Name: Brandon
LOL. RPF's and Volk TE's have been offered for Trucks for ages. Nothing new here.
Build Thread | Enter The Adventure | YouTube | Instagram
2006 V8 4x4 Limited JBL | ZOMB RNR
ZOMBRNR is offline   Reply With QuoteReply With Quote
Old 06-29-2018, 03:32 PM #6
89hatcher 89hatcher is offline
89hatcher is on a distinguished road
I wanna see how these would look on a 3rd gen 4runner
89hatcher is offline   Reply With QuoteReply With Quote
Old 06-29-2018, 03:52 PM #7
Same! We most likely are going to put a set on one of our reps 4Runners here (1999).
Depending on the response, Enkei may release a 17" & 18" version, in more bolt patterns. This is their first release in the new RPT1 series.
Old 06-30-2018, 05:42 PM #8
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
are those forged wheels? made in japan?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 06-30-2018, 06:54 PM #9
Tkblazer Tkblazer is offline
Tkblazer is on a distinguished road
Flow formed, made in one of the many factories enkei owns
2006 Limited 4wd | Dobinsons 2.5/1.5" lift | SPC UCA | 255/80/17 Cooper ST Maxx | 5th gen trail wheels | RCI sliders | Outgear Solutions rack | Kawell pods on CBI ditch brackets | Baja Designs Squadron sports
Tkblazer is offline   Reply With QuoteReply With Quote
Old 07-04-2018, 11:32 PM #10
Antmac Antmac is offline
Antmac is on a distinguished road
How good are Deadtires Back Country MT?
Antmac is offline   Reply With QuoteReply With Quote
Old 07-08-2018, 01:59 PM #11
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
Wish this version comes in 17"
slprciv is offline   Reply With QuoteReply With Quote
Old 03-12-2019, 01:47 PM #12
Enkei has just released an 18" version of this wheel - possible 17s are coming next!
We have Titanium Gold and Matte Dark Gunmetallic in 16 in stock and Gunmetallic in 18 as wel
Old 03-12-2019, 10:33 PM #13
Chris Walker Chris Walker is offline
Chris Walker is on a distinguished road
I have a hunch many people will initially overlook these wheels. They appear to be the off road version of the RPF1. The RPF1s are classics in automotive racing due to their high strength and very low weight.
If the RPT1s have nearly the same specs as the RPF1s you will be able to significantly reduce unsprung weight and potentially offset the entire weight variance from the 265 to the 285. If memory serves me right the RPF1s were 18-20 pounds for an 18 inch wheel... When you compare that to 30-35 pounds most wheels weigh, its significant....and the RPF1s are tough as nails.
I'm betting within a couple of years these will be a go-to for the wheeling community. I believe they will be a strong competitor in the Toyota community that currently uses the lightweight SCS wheels...
Chris Walker is offline   Reply With QuoteReply With Quote
Old 03-12-2019, 10:39 PM #14
bak3rme's Avatar
bak3rme bak3rme is offline
bak3rme is on a distinguished road
bak3rme's Avatar
i have the RPF1s on my Z. these are timeless wheels on a sports coupe, similar to TEs. not sure i'd run them on the 4runner tho.
'99 SR5 3.4L 2WD
SOLD
Build Thread
2003 Nissan 350z Track/Autocross
2014 4runner SR5
bak3rme is offline   Reply With QuoteReply With Quote
Old 03-13-2019, 02:42 PM #15
From TacomaWorld
HTML code is Off
Enkei Wheels Toyota Junkie 3rd gen T4Rs 14 03-06-2017 03:26 PM
OEM Enkei Wheels from 3rd Gen rfs324 For Sale: Suspension/Wheels/Tires 0 04-04-2016 04:34 PM
finally got my Enkei's back on w/ Japanese headlights 24runners Gallery 43 02-25-2016 01:39 AM
ID Some Enkei Wheels, Please =) A.Wilson013 3rd gen T4Rs 9 02-15-2013 10:01 AM
Does anyone here have Enkei RT6 wheels? Okie 4th Gen T4Rs 1 06-22-2009 06:25 AM
