Old 06-22-2021, 04:29 PM #1
Battle Born Offroad Battle Born Offroad is offline
Official Vendor
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Official Vendor
CSF All Aluminum Performance Radiator for 5th Gen 4Runner
Throughout the last decade, the CSF High-Performance brand has made its name in the motorsports world, but many will be shocked to find out that CSF’s roots actually come from the heavy-duty and off-road world of copper/brass radiators. Since the ‘70s CSF has sold tens of thousands of H.D. Toyota radiators dating back to 3rd gen Landcruisers and FJ40s. We’re bringing it back full circle in 2020, with a renewed focus on our off-road line of heavy-duty performance radiators, especially for Toyota Trucks and SUVs.
CSF is proud to announce the latest release to its growing late-model Toyota off-road series: CSF’s new (and industry exclusive) 5th gen Toyota 4Runner high performance and heavy duty all-aluminum radiator (CSF #7085).
Part Number: CSF7085 - Purchase Here! Use Code - T4R
There has been substantial growth in the Toyota off-road market, and enthusiasts are hitting the trails more than ever! Compared to some of the other SUVs on the market, the 5th Gen 4Runner is one of the major players in the US for those wanting a durable, truck-based SUV that’s as comfortable on the road as it is on the trail. As time has gone by, the demand for aftermarket performance parts has continued to grow. Enthusiasts continue to push the limits of their 4Runners – from driving in the desert sand dunes, navigating up mountain trails, to towing and hauling gear for overlanding and even partaking in extreme rock crawling and hill climbing.
Heat Soak Issues = Solved
One common issue found in such off-road activities is heat soak. Most off-road trails, especially rock crawling and hill climbing, are usually traversed at very low speeds with high engine power output. This can lead to engine and transmission overheating and leave drivers stranded, even in the desert or on a trail in the middle of nowhere with no rescue nearby.
Increased Performance
CSF’s new 5th gen 4Runner high-performance radiator fixes potential heat soak and overheating issues by increasing the capacity of the radiator and increasing the efficiency of the radiator core.
Utilizing CSF’s exclusive B-Tube Technology and increasing the core size from a tiny 1-row 22mm core to an ultra-efficient 2 row 42mm core, CSF has taken care of any worries of overheating. With the increased size of the radiator, CSF has also increased the capacity of the transmission oil cooler found in the bottom tank – this will help keep transmission temperatures in check, especially when towing.
CSF’s 5th Gen Toyota 4Runner all-aluminum 42mm 2 row high-performance radiator core vs. the OEM 1 row 22mm core
Maximum Durability
CSF has answered the call for increased performance and durability with its new 5th gen Toyota 4Runner All Aluminum Heavy-Duty Radiator. It’s the perfect answer to upgrading and safe-guarding against the weak OEM radiator with plastic end tanks.
OEM plastic/aluminum radiators make sense to produce in mass quantities to get cars and trucks through the assembly line and onto the road, but they come with many limitations – especially when drivers take their SUVs and trucks off-road or drive them in extreme conditions. After several years, the plastic tanks can start to become brittle from excessive heat cycles, can crack under heavy vibration, or can burst from extreme pressures and temperatures (including cold starts in freezing temperatures).
CSF’s 100% TIG welded all-aluminum end tanks prevent potential leakage when compared to the weaker plastic tanks that utilize a rubber gasket and a crimp design to seal.
For additional strength and reliability, all of CSF’s all-aluminum radiators have CNC machined mounting brackets and pins – a vast improvement over the OEM plastic mounting points, which can crack under high vibration or stress – common occurrences when off-roading or towing. Considering the retail price of an OEM Toyota 5th gen 4Runner radiator, for less than $100 USD more, one can upgrade to the CSF All Aluminum Heavy-Duty Radiator. A very small premium to protect against failures while also increasing your 4Runner’s performance.
CSF has recently partnered up with RPM Off-Road Garage for test fitment into one of their shop’s 5th gen 4Runners. Thanks to Al (@sponsoredbywifey) for testing the radiator in real world conditions through daily driving, long road trips, and many off-road excursions.
High-Performance Radiator (#7085) Features:
2 Row, 42mm Ultra High-Performance Core Featuring CSF’s Exclusive B-Tube Technology
Core Features Ultra-Efficient, 6.5mm Tall Fins with a Multi-Louvered Design for Maximum Surface Area Contact
Upgraded 4-Plate Automatic Transmission Cooler Built Into Bottom End Tank
Individually Leak and Pressure Tested
CNC Machined Mounting Brackets for Superb Fit and Durability
100% All Aluminum TIG-Welded Construction
True “Drop-In-Fit” Requires No Modifications to Install
1 Hour “Mirror Finish” Hand Polish
2 Year Limited Warranty
Use code T4R
OEM Numbers: 16400-31710, 16400-31711, 16400-31712, 16431713 & 16410-AZ030
Pricing: MSRP – $529.00 USD
Fitment: 2010-2020 (5th gen) Toyota 4Runner (4.0L & 2.7L)
T4R Forum Discount - use code T4R
BATTLE BORN OFFROAD
Las Vegas, NV | 702.333.0868
The Offroad Part Source
Battle Born Offroad is offline   Reply With QuoteReply With Quote
Old 09-14-2021, 12:34 PM #2
Longv Longv is offline
Longv is on a distinguished road
Any updates on when these will ship
Longv is offline   Reply With QuoteReply With Quote
csf , gen , off-road , radiator , toyota
HTML code is Off
Griffin Radiator - Combo Aluminum Radiator + eFan Conversion with Shroud JONBOY345 4th Gen T4Rs 3 08-25-2020 09:12 PM
CSF New High Performance Aluminum Radiator Battle Born Offroad Engines / Suspension / Wheels / Tires / Audio / Accessories 6 04-06-2020 04:17 PM
CSF New High Performance Aluminum Radiator Battle Born Offroad Group Buys 0 03-19-2020 06:39 PM
CSF New High Performance Aluminum Radiator Battle Born Offroad 5th gen T4Rs 0 03-19-2020 06:29 PM
Koyo racing / performance aluminum radiator Dezerts10 3rd gen T4Rs 6 02-12-2020 02:56 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
