Old 11-23-2021, 06:35 PM #1
Battle Born Offroad Battle Born Offroad is offline
Official Vendor
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Official Vendor
ELEMENT HARD PARTS BLACK FRIDAY - Save $200 on Billet UCAs!
On Sale Now for Black Friday!!
CLICK HERE TO ORDER - USE CODE BFCM21
We are constantly on the hunt for new 4Runner products and upgrades that we can offer to the growing owners group. When it comes to upper control arms, we believe we have found the best in ELEMENT Hard Parts. Yes, there are plenty of upper control arms out there. And, for lots of good reasons. Aftermarket upper control arms allow for more wheel travel than factory arms. High-angle uniballs not only offer more strength, but also provide more angularity to get every inch of wheel travel available. They allow for proper alignment, improved coil spring clearance at full droop, and use stronger materials. But, Element Hard Parts arms are built to be the best. What makes them better than the rest? Let's take a look.
Element Billet Aluminum Control Arms are milled out of a solid chunk of 6061-T6 aluminum billet by an advanced five-axis CNC machine. This process definitely isn't the cheapest way to make control arms, but it is the best way. There is no welding or tube fitting necessary. Milling the arm is a more precise process allowing our control arms to be built precisely to our tolerances and specifications. Using 6061-T6 aluminum also enables our control to arms to be lighter and completely rust-free. We didn't cut corners anywhere on our Element Billet Aluminum Control Arms. Some will cheap out on the other parts of a control arm, but not us. We use high-end -inch FK rod ends with PTFE liners and a clear zinc finish. Our misalignment spacers are made from high-quality 303 stainless steel. To craft our adjustment sleeves, we utilize 1020 steel with a clear zinc finish. Those same sleeves feature a hexagon shape with ¼-inch machined holes, making them easy to adjust. We even went to town on the dust cap machining it from 6061-T6 aluminum and equipping it with an O-ring seal to protect the uniball. All of our quality components and attention to detail create a high-strength, high-end arm that is a cut above the rest.
KEY ATTRIBUTES
  • Precision 6061-T6 billet aluminum construction using a five-axis CNC machine
  • Premium heat-treated ¾-inch FK rod ends with PTFE liners and a clear zinc finish
  • Super stout 1-inch diameter FK heat-treated and hard chrome-plated uniballs made from 52100 steel
  • FK stainless steel heat-treated uniball races with PTFE liners for durability and extended life
  • Custom-made 17-4 stainless steel heat-treated pins and caps for maximum strength
  • Misalignment spacers made from high-quality 303 stainless steel
  • 6061-T6 billet aluminum dust caps with integrated O-ring seals that protect the uniballs and look great
  • Vehicle-specific chamfers for maximum coil and reservoir clearance
  • Premium clear zinc coated Allen fasteners for use in the pinch bolts and dust cap
  • Mil-spec Type III hard-anodized finish for the ultimate in protection
Element Hard Parts Tube Upper Control Arms are built with the same commitment to high quality, advanced engineering, and strength as our billet arms. While they are a lower-cost option compared to our billet arms, we dont skimp on their construction or components. Instead of cheap, lower-grade steel, our arms are built using CNC-bent 1.25-inch diameter, .120-inch thick 4130 chromoly. Thats the good stuff people. We treat our tube arms to the exact same beefy 1-inch FK uniballs and custom machined 17-4 heat-treated stainless steel pins as our billet arms. Our Tube Upper Control Arms are made to handle plenty of abuse and look great while being affordable.
KEY ATTRIBUTES
  • Built using CNC-bent 1.25-inch diameter, .120-inch wall 4130 chromoly tubing
  • Innovative squeak-free, zero maintenance bushings that require no grease
  • Built-in camber and caster for proper alignment and improved handling
  • Designed for maximum clearance and wheel travel
  • Two-stage gloss black powder coat with clear finish
  • Reinforced bushing pivot barrels
  • OE-style ABS routing provisions
Element Hard Parts Tube Upper Control Arms use an innovative self-lubricating bushing design that requires zero maintenance or lubrication and do not squeak. They never bind and allow for unlimited rotation and free pivoting. An 85 Durometer compound makes our bushings much firmer than OEM bushings for better handling, but softer than polyurethane ones for a plusher ride and reduced NVH. And, unlike some OEM bushings, ours are fully bonded and sealed to keep any containments from entering the pivot points so they are built to last. Sound too good to be true? They are backed by lifetime warranty so there are no worries. Eliminate the squeak, eliminate the maintenance, and eliminate the mess.
Big Balls - Element Upper Control Arms yield a massive increase in strength over the puny stock ones currently on your truck. Serious strength gains come from the big 1-inch FK uniballs found on every Element arm. The race of the uniball is made from heat-treated 17-4 stainless steel, while the actual ball uses a super-hard 52100 steel that is heat-treated and chrome plated for maximum durability. We even custom machine a 17-4 stainless-steel heat-treated pin to create an arm that can take whatever punishment you can dish out.
Toyota Application List:
03+ 4Runner / FJ / GX Tubular UCA - 1015
03+ 4Runner / FJ / GX BILLET UCA - 1005
05+ Tacoma Tubular UCA - 1014
05+ Tacoma BILLET UCA - 1004
07+ Tundra Tubular UCA - 1016
07+ Tundra BILLET UCA - 1006
BATTLE BORN OFFROAD
Las Vegas, NV | 702.333.0868
The Offroad Part Source
Battle Born Offroad is offline   Reply With QuoteReply With Quote
arms , billet , control , heat-treated , steel
HTML code is Off
ELEMENT Hards Parts Upper Control Arms - Best UCAs on the market?? Battle Born Offroad 5th gen T4Rs 5 11-25-2021 05:15 PM
ELEMENT Hards Parts Suspension - Summer GROUP BUY! ****Best UCAs on the market!**** Battle Born Offroad Group Buys 2 11-23-2021 05:31 PM
ELEMENT Hards Parts Suspension - Summer GROUP BUY! ***Best UCAs on the market!*** Battle Born Offroad Battle Born Offroad 1 06-22-2021 03:59 PM
Anyone SAVE BIG ordering your parts on Black Friday? ? ? ? ? infamousRNR General Discussions 1 06-28-2014 07:19 PM
