Old 05-13-2022, 03:51 PM #1
Battle Born Offroad Battle Born Offroad is offline
Official Vendor
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Official Vendor
Battle Born Offroad Shock Services - Las Vegas Shock Rebuilds
Battle Born Offroad Shock Service & Rebuilding
Battle Born Offroad has everything you need to keep your shocks preforming at their best. Our Las Vegas Shock Rebuild service is for daily drivers, weekend warriors, prerunners, overlanders, racers and more! Below is our general price menu of shock refresh and revalving services. Price may be higher if product is severely damaged and requires replacement parts that will exceed original estimate. BBO will call you with a revised estimate for your approval prior to work being started.
SHOCK REBUILD / REFRESH SERVICE
We start with a deep cleaning to remove grease, shock oil, dirt and other road grime. Our citrus based cleaners do not harm shock finishes or anodizing. After a deep clean, a thorough shock inspection is performed to look for damage and/or wear. From there, we perform a complete tear down and rebuild of damper, including new seals, fresh oil, debur and polish shock shaft and nitrogen recharge. All consumables and labor are included in prices below.
$200 PER PAIR
2.0 IFP*
2.0 Emulsion*
2.0 Air Shock
2.0 Bump Stop
2.0 Remote Reservoir CO
2.0 Bypass
2.0 Piggyback CO
2.5 Air Shock
2.5 Bump Stop
2.5 Emulsion*
*We do not rebuild / service IFP shocks that do not have a schrader valve (no nitrogen pellets, return to manufacturer for service).
$250 PER PAIR
2.5 Remote Reservoir
2.5 Kit RR Coilover
2.5 Piggyback
3.0 Remote Reservoir
Most UTV Shocks
$320 PER PAIR
2.5 Bypass
2.5 Internal Bypass
3.0 Bypass
XP 1000 Front
$540 PER PAIR
3.0 Internal Bypass
3.5 Bypass
XP 1000 Rear
$640 PER PAIR
4.0 Bypass
$750 PER PAIR
4.4 Bypass
2010-2014 OE Ford Raptor Full Set (4 Shocks)
$700
2017-2018 OE Ford Raptor Full Set (4 Shocks)
$725
2019+ OE Ford Raptor Live Valve Shocks Full Set (4 Shocks)
$800
SERVICE & UPGRADES
Remove & Reinstall Shock (Per Shock) - $65
Bring us the shocks off the vehicle to save on this labor charge.
Remove & Reinstall Spring from Coilover (Per Shock) - $20
Included in UTV & OE Applications, for all others $20 to remove and reinstall the spring and spring seat.
Viton Seal Kit Upgrade – $20 per shock
Top Quality Viton Seals throughout the shock(s).Viton seals have a high temperature range, and are perfect for use in extreme prerunner, play, and race applications. May leak on street driven, low heat applications.
Install UTV Spring Kit - $350
Remove shocks, install spring kit to manufacturers specs, test and re-check rideheight, make final adjustments.
Extra services - call for pricing
We can add compression or dual speed compression knobs to shocks, add remote or finned reservoirs, convert shocks from piggyback to remote, replace hoses, replace bearings, replace bushings, anodizing and shock color customizing, etc. Contact for details!
BATTLE BORN OFFROAD
4301 S Valley View Blvd
Unit 19
Las Vegas, NV 89103
702.333.0868
Info@BattleBornOffroad.net
BATTLE BORN OFFROAD
Las Vegas, NV | 702.333.0868
The Offroad Part Source
Battle Born Offroad is offline   Reply With QuoteReply With Quote
bypass , pair , service , shock , shocks
HTML code is Off
Jake@Battle Born Offroad chicklet Feedback on Sellers & Buyers 1 10-23-2019 05:48 PM
RIGID AMBER SAE - Now Available @ Battle Born Offroad! Battle Born Offroad Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-23-2019 05:37 PM
Shock Rebuilds WA Matteblack 5th gen T4Rs 4 03-16-2019 12:11 AM
C4 FABRICATION at Battle Born Offroad! Battle Born Offroad Battle Born Offroad 0 11-07-2018 05:09 PM
