Old 05-18-2017, 08:50 AM #16
roninookami's Avatar
roninookami roninookami is offline
roninookami is on a distinguished road
MY GARAGE
MY GARAGE
Hardware question
Originally Posted by C4 Fabrication View Post
Hey everyone, we have been working on getting install instructions put together for our current products. Here is what we have for the rock sliders right now. (See PDF attachment at bottom of this post)
I have had a few people ask how the washers go on the bolts that are provided with the sliders. The split lock washer goes on the bolt first, and then the grade 8 flat washer goes next.
For all of you guys with KDSS systems, we have not had access to a KDSS 4runner yet to do an install and take photos. Basically the sliders install the same as the regular sliders. The only difference is that you need to un-bolt the KDSS hydraulic lines from the side of the frame rail and pull them away from the frame far enough to fit the rock slider frame plate up behind them. Then the KDSS lines get bolted back into the same location as before using the 8mm bolts provided by us.
Here is a good link with pictures for the KDSS guys: How to: Install Rock Sliders with KDSS
Getting ready to install my sliders and checking the hardware. I didn't recieve any split lock washers only flats. Can I install without them or do I need to get some. Thanks.
roninookami is offline   Reply With QuoteReply With Quote
Old 06-01-2017, 05:17 PM #17
CrazyMike's Avatar
CrazyMike CrazyMike is offline
CrazyMike is on a distinguished road
CrazyMike's Avatar
FYI
I just got off the phone with Caleb and because C4Fab has switched to flanged bolts, the split ring washers are no longer necessary.
The flanged bolts with the flat washers are sufficient to provide the necessary clamping force.
https://photos.smugmug.com/photos/i-fP97x8D/0/S/i-fP97x8D-S.jpg
2016 4Runner TRD Pro in Super White, BFG 275/70R17, Gobi Stealth, CVT Mt. Shasta Extended Summit Series RTT, Genesis Off Road Dual Battery System
CrazyMike is offline   Reply With QuoteReply With Quote
Old 06-01-2017, 08:08 PM #18
C4 Fabrication's Avatar
C4 Fabrication C4 Fabrication is offline
Real Name: Caleb
C4 Fabrication has a spectacular aura about C4 Fabrication has a spectacular aura about
Real Name: Caleb
The split washers are no longer needed. Go ahead and use just the flange bolt and flat washer.
Owner/Operator of C4 Fabrication. specializing in custom built Toyota off-road products.www.c4fabrication.com
C4 Fabrication is offline   Reply With QuoteReply With Quote
Old 06-12-2017, 07:28 PM #19
Discovery Discovery is offline
Discovery is on a distinguished road
I think I'm missing those 2x 3/8 thread cutting screw for the cross member...
Discovery is offline   Reply With QuoteReply With Quote
Old 10-05-2017, 11:56 PM #20
WLSchroder WLSchroder is offline
Real Name: Walt
WLSchroder is on a distinguished road
MY GARAGE
Real Name: Walt
MY GARAGE
Just ordered mine!
Just ordered my sliders tonight after talking to Caleb today. Looking forward to getting them!
Question: Is anybody applying any Loctite (red or blue) prior to installing the bolts? Also, for the holes that are being drilled into the frames, has anybody had any thoughts on painting the holes for rust prevention? Granted, I live in the desert (it's a dry heat!) but I still wonder if its not a bad idea?
WLSchroder is offline   Reply With QuoteReply With Quote
Old 12-22-2017, 01:18 PM #21
DavidJ73 DavidJ73 is offline
DavidJ73 is on a distinguished road
Unhappy 2014+ 4Runner C4 Rock Sliders - For Sale
I have a set of brand new C4 Rock sliders for sale. They are for 2014+ 4Runner They have the bolt on step pads, and TRD Pro Text. I had them disassembled, blasted, zinc coated, then powder coated. They will not fit vehicles with KDSS system. Hence I'm selling them. They cost me $878 from C4, plus $320 for prep and coating. So I have almost $1,200 into these things. Expense mistake. I have a 2018 TRD Off road (Pro build) w/KDSS. Didn't want to pay silly $$ or wait months for a PRO from the dealer. Lesson learned - don't shop for expensive gear late a night when you've just got done changing our your intake system and lights. I live in Broomfield CO, but will ship elsewhere.
DavidJ73 is offline   Reply With QuoteReply With Quote
Old 12-29-2017, 02:53 PM #22
I have a set of these for sale
I mistakenly bought a set of these for my 2018 4R with KDSS. The type I bought will only work for non KDSS vehicles. C4 won't take them back or modify them. So I need to sell them and order the right sliders.
Old 12-30-2017, 01:29 PM #23
Real Name: Caleb
Real Name: Caleb
Did you talk to anyone at our shop about returning them? Its not that we wont take them back, its just that you would need to pay shipping to get them back to us.
Old 03-01-2018, 04:20 AM #24
stevenX stevenX is offline
stevenX is on a distinguished road
you do not need to cut any of the KDSS skid plates. The only thing you need to do is hammer the little bent tabs on the ends of the KDSS skid plate so they flatten out before putting the skid back on.
Hi Caleb,
For your current production sliders, do we need to flatten out the KDSS skid plate tabs still?
Also, do we need to drill on the passenger side still? Just wanted to make sure as your website says no drilling required, but the install instructions have a step for drilling.
stevenX is offline   Reply With QuoteReply With Quote
Old 03-01-2018, 10:19 AM #25
Real Name: Caleb
Real Name: Caleb
Originally Posted by stevenX View Post
Hi Caleb,
Yes the skid plate tab will need to be flattened. Drilling on the passenger side is optional and not required.
Old 03-01-2018, 09:51 PM #26
Awesome!!
Old 12-23-2019, 06:01 PM #27
alisadunkerk alisadunkerk is offline
alisadunkerk is on a distinguished road
If you hire expert writing services you will be able to work with a professional and subject-oriented essay writer who knows how to keep deadlines.
alisadunkerk is offline   Reply With QuoteReply With Quote
HTML code is Off
RCI Rock slider install instructions? Cgullo83 5th gen T4Rs 53 01-21-2019 06:09 PM
Shrockworks rock slider install instructions coletrain09 5th gen T4Rs 57 11-28-2018 08:42 PM
Savage Off Road Rock Sliders Install (Lots of Pics and a Welding Video) wmeredith 3rd gen T4Rs 16 04-20-2018 11:55 AM
Anyone have the instructions for MeatlTech sliders? razzman1 4th Gen T4Rs 2 08-12-2015 03:28 PM
welding on sliders - instructions? MadCityRich 3rd gen T4Rs 5 06-25-2012 11:26 PM
Copyright © 2019
