What year? It sounds like a pressure issue. An inline fuel pump, like was used once, operated at lower PSI than in tank pumps. In tank pumps also slightly pressurize the tank to help with fuel transmission.
My guess is by installing an external, in line, pump you are not building up enough pressure?
Why not replace the intank pump with a cheap aftermarket built to spec? Surely that has to be a simpler solution than attempting to jury rig a 3rd part solution and to trouble shoot the inevitable problems that are going to crop up?
