Old 01-25-2020, 12:11 PM #811
kc15842 kc15842 is offline
Real Name: Kevin
kc15842 will become famous soon enough
Real Name: Kevin
Originally Posted by JZiggy View Post
Recently took my 88 out of storage and have been working out the kinks. Redid the front end: new steering joints all around, new V6 calipers and rotors, wheel bearings repacked.
I forgot how much work it is changing out rotors on this design!
I just did the same thing, I had a pair of rebuilt calipers, had the thicker rotors turned and they bolted right up after slight clearance cuts to the guards. IMO they feel more responsive
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
kc15842 is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 10:59 PM #812
M.fate M.fate is offline
Real Name: Sean
M.fate is on a distinguished road
Real Name: Sean
Angry
I ripped my 86 apart trying to find the short thats causing my dash light and tail lights to be non-op. It’s not the fuse, the dimmer, the relay, corrosion on the bulbs or the trailer hook-up(I don’t have one but I read that was a cause so I look for it.)
I’m stumped and annoyed.
M.fate is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 12:42 AM #813
4Reak Show's Avatar
4Reak Show's Avatar
That sucks. Sounds more like an open than a short. Curious about your method of testing and whether or not you have a wiring diagram on hand. That system should be pretty straightforward for finding where the power or ground is vanishing.
Old 02-06-2020, 05:25 PM #814
toyobama toyobama is offline
toyobama is on a distinguished road
I am currently restoring my 86 T4R
toyobama is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 06:16 PM #815
r4ffi r4ffi is offline
r4ffi is on a distinguished road
I changed most of the interior-lighting to blue (to match my radio-color).
r4ffi is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 06:26 PM #816
Crimson Wolfe Crimson Wolfe is offline
Real Name: Kieran
Crimson Wolfe is on a distinguished road
Real Name: Kieran
Hopefully found a source for a new throttle body assembly for my '87 ....
"Life is a journey, not a destination."
Crimson Wolfe is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 07:10 PM #817
lewiswilkinson's Avatar
lewiswilkinson lewiswilkinson is offline
lewiswilkinson is on a distinguished road
Only just bought mine... but it needs
Fan motor
Front right wheel bearing
Drivers door lock replaced...
lewiswilkinson is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 07:38 PM #818
Real Name: Sean
Real Name: Sean
You would think. My not very savvy when it comes to electrical. From the time I first posted to now I found a proper FSM wiring diagram.
Yet I’m still battling this issue. I get power to the tail light relay, the headlight switch will send power to the fuse. , however once that happens it pops the fuse. I’ve tried isolating the issues by disconnecting everthing that comes off that fuse. Custer lights, taillights, light reminder (buzzer), cruise control switch, the damn clock and all other dash lights...it still pops the fuse the moment power is applied.... I’m pretty stuck...my last guess is something forward of the relay..or..maybe I’m getting to much power some how.
Old 02-16-2020, 02:30 PM #819
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
I ripped my 86 apart trying to find the short thats causing my dash light and tail lights to be non-op. .
How di u make sure it's not the fuse, the dimmer, etc? Got multimeter?
What did you do with your classic T4R today?-taillight_test_points_1280-jpg
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 02:40 PM #820
Kutanks Kutanks is offline
Kutanks is on a distinguished road
Over the weekend I pulled the trigger on a 1990 V6 5 Speed 4WD SR5! Very excited to start working on her but i don't have plates yet. So that is first up. Next i will start replacing some of the worn out parts and do a general tune-up.
Kutanks is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 11:52 AM #821
cjalexander's Avatar
cjalexander cjalexander is offline
cjalexander is on a distinguished road
Replaced window motor
Replaced the passenger window motor in the '87.
Up next: more troubleshooting on the rear window so I can swap the top.
cjalexander is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 10:45 PM #822
counterculture counterculture is offline
counterculture is on a distinguished road
Congrats! Would love to see some pics
counterculture is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 10:17 PM #823
jasindude1 jasindude1 is offline
jasindude1 is on a distinguished road
just bought it, drove it home today!
purchased my 1st 4runner 94 with 241k. Bought as a around town vehicle. 4wd, manual. Paid $1200, needs a lil work, but hope this site can help me with that
What did you do with your classic T4R today?-4runner-jpg
jasindude1 is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 01:54 AM #824
delta18 delta18 is offline
delta18 is on a distinguished road
Me too. Only recently acquired it. Put on new front fenders over the weekend and am working to sort out some surface rust.
delta18 is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 03:16 AM #825
GoMopar440 GoMopar440 is offline
GoMopar440 is on a distinguished road
What did I do? Ordered more parts for it. Today it was a CAI kit and windshield washer bottle from Fleabay.
So far I've also ordered, but not yet installed, a bunch of other parts.
- A set of stainless headers
- An aluminum 3 row radiator w/shroud and electric fan
- A LC Engineering EGR block off kit
- Moog HD stock height rear coils
- A 1" body lift
- A new throttle cable
- A bunch of parts from the dealer to get the rear tailgate glass to function properly.
The body lift is only going on if/when I decide to pull the trigger on a 3.4 swap. For now the new rear coils will give me all the lift I'll need for a daily driver.
This list is a little late, but here's the stuff I've already done, or had done, since I bought this high mile (242K) but basically stock 2nd gen a couple of weeks ago.
- Replaced the rotten tires with Hankook MT2's (30x9.5R15)
- Fixed the sunroof (replaced the switch)
- Changed the oil and filter
- Replaced the broken windshield
- Replaced the broken power antenna
- Added a pair of KC lights to the brush guard
- Replaced the factory stereo with a large display double DIN head unit
- Replaced the blown factory speakers
- Added a back up camera
I'm sure I'm probably forgetting a few things, but that's most of it for now.
'94 4Runner SR5 4x4, 3.slow/AT. all stock except for a grille guard and 30/9.5r15 MT tires.
GoMopar440 is offline   Reply With QuoteReply With Quote
Well this classic just crapped out on me hadjii Classic T4Rs 20 12-23-2011 03:09 PM
Classic Sighting... Diagram14 Classic T4Rs 9 04-28-2011 07:34 PM
wasting Gas (classic gen) hchernan Classic T4Rs 3 04-24-2006 09:12 PM
..with a classic IPod? fit_of_vanity Engines / Suspension / Wheels / Tires / Audio / Accessories 1 01-01-2005 08:43 PM
Classic PRICELESS Pic! Thai Off Topic 26 01-03-2004 08:11 PM
