Old 03-08-2022, 07:16 PM #871
TLar25's Avatar
TLar25 TLar25 is offline
Real Name: Taylor
TLar25 will become famous soon enough TLar25 will become famous soon enough
TLar25's Avatar
Real Name: Taylor
Originally Posted by WillCody86 View Post
Scored some leather seats from a 2nd gen in fairly good condition. Threw some Noico sound deadening under the floorboard and in the door panels while I had the opportunity to. Will proceed to sound deaden the back once it gets warm enough to switch to the softopper and pull the sleeping platform out while tops are in transition. I’ll have a lot more room to work then. These seats are much more comfy than the previous Summit Racing seats I had in them!
Noticeable difference with the sound deadening?
Sent from my Pixel 3 XL using Tapatalk
1985, 22re, 5spd, 4x4, Marlin crawler dual transfer case, locked fr&rr, 35's
1996, 5vz-fe, Auto, 4x4, Bilstein/ome lift, tundra 17's, 33's
Sold(regret it)- 1999 Highlander edition, Auto 4x4, 3"lift, factory rear locker
TLar25 is offline   Reply With QuoteReply With Quote
Old 03-09-2022, 01:58 PM #872
WillCody86's Avatar
WillCody86 WillCody86 is offline
Real Name: Will
WillCody86 is on a distinguished road
WillCody86's Avatar
Real Name: Will
Slightly so far. I still need to do the back and then I think I’ll really be able to tell a difference. There’s a night and day difference with the doors, though. Knocking on them before vs after sound deadening made it easy to tell a difference.
"Billy Goat" - 1986 4Runner, 22RE 5-speed, 33x10.50R17 Goodyear Wrangler MTR, 4.88 diffs, 4.7 TG t-case, OME HD springs, OME Nitrocharger Sport Shocks front and rear, Detroit locker in the rear, other goodies
WillCody86 is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 09:12 PM #873
FLdanny FLdanny is offline
FLdanny is on a distinguished road
Took my first gen to the beach for the first time
FLdanny is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 11:35 PM #874
Bjankins1 Bjankins1 is offline
Bjankins1 is on a distinguished road
We just got a 95 SR5 a few months back, currently it needs
Axle shafts, ball joints, control arms, rotors, pads, new valve cover gaskets and cam plugs, a coolant flush, transmission pan gasket needs to be replaced and so does the oil pan gasket
It's gonna be a bit job, on top of that the speedo cable is bad and the knock sensor harness is throwing a code too
Bjankins1 is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 06:58 PM #875
Batmmannn Batmmannn is offline
Batmmannn is on a distinguished road
I can't post a new thread yet so I'm asking here.
How does a bad ground effect the EFI fuse? I have a 93 3.0 and it's blowing the EFI with every attempt at starting.
O2 sensors wires are fine. Replaced Relays, new fuel pump, disconnected AFM and VSV. No change.
Only blows when starting and not in the on position. I'm extremely frustrated. Swapped the Computer and no change.
I'm going nuts here. I can't find anything wrong but as soon as you turn the key and the starter is turning it blows the EFI FUSE.
any ideas or help would be greatly appreciated. Thanks
Batmmannn is offline   Reply With QuoteReply With Quote
Old 03-01-2023, 07:00 PM #876
Cool
I'm going nuts. can't find anything wrong but as soon as you turn the key and the starter is turning it blows the EFI FUSE.
any ideas or help would be greatly appreciated. Thanks in advance.
Old 07-09-2023, 09:48 AM #877
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Washed and waxed it, also gave it an oil change!
JZiggy is offline   Reply With QuoteReply With Quote
Old 07-12-2023, 07:25 PM #878
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
This is actually from a few weeks ago.
Picked up a top for $75 *plus 3 hours of driving* so that I can get the L-Trim that had zero rust. The current trim is rotting away on the 88. The glass went to another user in California. It was over-all a win win!
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 07-14-2023, 06:25 AM #879
dtme30 dtme30 is offline
dtme30 is on a distinguished road
Did you recently replace a part before this started happening? Had this similar thing happen when I replaced my alternator.
Turns out the new part or “rebuilt oem” alternator purchased on eBay was poorly rebuilt from the person who purchased it from and it kept blowing that 30 amp fuse every single time as well. Got the doofus to send out a total of 3 different alternators out and they all gave different problems.
Got a proper rebuilt replacement from Autozone and haven’t had any problem since. My guess was internal shorting in the first alternator. Best of luck to you.
dtme30 is offline   Reply With QuoteReply With Quote
Old 07-19-2023, 02:41 PM #880
Marvin Berry's Avatar
Marvin Berry Marvin Berry is offline
Real Name: David
Marvin Berry is on a distinguished road
Real Name: David
So smart, on this with my seat asap. Thanks!
Marvin Berry is offline   Reply With QuoteReply With Quote
Old 10-24-2023, 07:19 PM #881
Zanz25 Zanz25 is offline
Zanz25 is on a distinguished road
Drove my new 86 turbo to work today.
First time taking it over 40mph. Found a wickedly shrill air leak.
Anyone have a work around for the Out of production rubber seals on side windows and sunroof?
Zanz25 is offline   Reply With QuoteReply With Quote
Well this classic just crapped out on me hadjii Classic T4Rs 20 12-23-2011 03:09 PM
Classic Sighting... Diagram14 Classic T4Rs 9 04-28-2011 07:34 PM
wasting Gas (classic gen) hchernan Classic T4Rs 3 04-24-2006 09:12 PM
..with a classic IPod? fit_of_vanity Engines / Suspension / Wheels / Tires / Audio / Accessories 1 01-01-2005 08:43 PM
Classic PRICELESS Pic! Thai Off Topic 26 01-03-2004 08:11 PM
