Good news: The reservoir is in and pumps as it should.
Bad news: One of the 'squirters' is screwed up. On the underside of the hood, one has a 90 degree tube attached to a black stem (and I've connected it) but the other is missing the tube and stem. My guess is it's been broken off. Is this a common part I can get anywhere? Or is it specific to Toyota?
TIA,
Jon
Originally Posted by SV_Dude
You can go to your local auto parts store and get some tubing. Routing should be self explanatory. Route the tubing on the passenger fender and to the hood. Use a "Y" piece to divide the tubing to each sprayer on the hood.
It's been so long since I scrounged the parts from my BIL's old truck that I'd forgotten I'd also taken some tubing. With what he gave and what remained in my truck I was able to run the tubes (except as described above).
Where are you coming from? I'm about an hour and a half up the 24 from mboro. I'm in Clarksville, if it's on your way I'll give you a hand with it if you need.
Tucson. About 1670 miles. Plan to use 3 days. The intention is to get this particular issue fixed before the roadtrip.
I also plan to install an Audiovox aftermarket cruise control. We'll see how that goes. I have the same unit on my Honda motorcycle and it works great.
Thx,
Jon
