Vitals: 92 4runner 3Vze with Auto tranny and 4wd
Ok, ive searched for a while and havent found any answers. I am having problems with my shift lock solenoid not disengaging to allow me to shift from park. I've heard intermittent clicking every once and a while like either the solenoid or ecu were going out.
Normally when you depress the brake you hear the "click" which is your solenoid allowing your gear selector to move to a gear. When i depress mine i hear nothing anymore. I have to use the shift lock bypass to get into gear.
I read the fsm and it had me ohm out my solenoid and measure voltages coming from the plugs on the ecu unit located under the console. Everything checked out fine except my output to the solenoid. Instead of reading 10-14 Volts it read 0.7. This is extremely low and tells me either the ecu is toasted or ive got a short somewhere. I looked at the brake pedal and couldnt see exactly which switch was interlocked to send the signal to the ecu.
Has this every happened to anyone before? i have found ecus for 50 bucks on ebay, but i want to make sure its the ecu before i buy it.
Josh
ECU
