Old 02-13-2012, 07:56 PM #1
Atomic_Dog Atomic_Dog is offline
Atomic_Dog is on a distinguished road
Right front axle play at the differential
I was checking out the new (1995) to me 4runner and noticed the left right cv joint has a lot of play at the diff. The play is in the diff where the cv goes in. Is this normal? I couldn't find any threads after doing a search. Thanks
2001 SR5 130k miles
Atomic_Dog is offline   Reply With QuoteReply With Quote
Old 02-13-2012, 09:08 PM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
I know you said left front, but do you mean the passenger front? The splines get loose over time, and there is a bearing in there..but As long as its not leaking its probably fine. Its alot of work to pull that diff out.
Happened to me this summer:
IFS diff Issues. - YotaTech Forums
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 02-13-2012, 09:14 PM #3
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
I've been told that a little play on the axle shafts is normal, and not a huge deal unless it's leaking or grinding or otherwise misbehaving.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 02-13-2012, 10:30 PM #4
Yep. Right side. The left side has a torn boot and no grease. groan. The valve covers are leaking too badly to tell if the diff is leaking. I picked up the gaskets for the valve covers so once they're done I'll know more. I may just toss some UV dye in the diff. Nothing like buying a vehicle with 174k miles on it. Luckily it's a Toyota and was garage kept so the body is fine.
2001 SR5 130k miles
Old 02-13-2012, 10:48 PM #5
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Smell the oils. Haha. Diff oil smells very different than engine oil.
IG: rattlewagon
Old 02-14-2012, 06:34 AM #6
I tried to smell the oil, check the viscosity etc. when I noticed the play. I didn't detect any gear lube, but everythings pretty soaked from the valve cover leaks. I'll replace the diff seal when I install the new alxles while changing the uneven brake disc while... Good times.
2001 SR5 130k miles
Old 02-14-2012, 04:10 PM #7
Real Name: Kevin
Real Name: Kevin
Soak it down with some grease killer, Simple Green or that purple stuff.
And unless it's leaking, don't worry about the play. I asked my gear guy how much play was normal there, and his exact words were "just a bit more than you think there ought to be".
Center differential + rear differential + front differential = confusion! badburro 5th gen T4Rs 37 01-29-2019 12:40 PM
HELP! Is this too much play in my front diff? Jon 3rd gen T4Rs 8 07-03-2011 09:58 AM
Feeler: Front Speakers plug and play 50 shipped CONUS simple Classifieds - buy & sell (no commercial ads please) 0 02-27-2010 10:02 PM
Front Pass Side Wheel Excessive Play - (pix) californiak 3rd gen T4Rs 4 08-21-2007 05:42 PM
Play in front wheels mijo Problems & Warranty Issues 3 09-12-2006 11:05 AM
