Old 02-22-2012, 05:30 AM #1
huntermac50 huntermac50 is offline
huntermac50 is on a distinguished road
HELP: starts up then dies, what could this be? VIDEO included!
Hey everyone,
new to the forum, and i think some of you might be able to help me out.
after replacing a blown head gasket on my 1994 3.0 3VZE, everything went back together fine and now she starts up but will not stay running.
check out the video! opinions anyone? anything helps!
4runner.MOV - YouTube
huntermac50 is offline   Reply With QuoteReply With Quote
Old 02-22-2012, 05:38 AM #2
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Welcome to the board. I didn't see the part where the truck starts, did you leave something out?
It looks to me like it wants to catch but isn't quite getting there. You need air, fuel, spark, compression, and timing, and if you're missing any of those things it could behave just like that.
Pull each plug, leave it in the plug wire, and hold it near the block while somebody turns the ignition, you should see an arc. That's a basic test, but it's enough for now. While you're doing that, take a big whiff of each open cylinder immediately after cranking, and make sure you smell gas. If you've got spark and gas, borrow a compression tester from autozone and make sure your cylinders are good. That's the easy stuff, if that all checks out then refer to the FSM (link in the sticky up top of this forum) troubleshooting section for anything else I might have missed.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 02-22-2012, 05:49 AM #3
well starts up then INSTANTLY dies haha it catches for a second.
so far i have test for spark, have spark on all 6. tested compression, over 140 on all. you can smell fuel when you crank it with the plugs out and you can also smell a hint of fuel on the plugs themselves. i only got it so "start" this much when i advanced the timing quite a bit.
anything else im missing?
Old 04-16-2016, 03:30 AM #4
2ndgenmafia 2ndgenmafia is offline
2ndgenmafia is on a distinguished road
Originally Posted by huntermac50 View Post
Hey everyone,
i am having the SAME exact problem... except i only replaced the knock sensor. put it all back toegther, and this is what i got. did you do anything to fix this issue?
2ndgenmafia is offline   Reply With QuoteReply With Quote
Old 04-17-2016, 10:21 PM #5
sdb999 sdb999 is offline
sdb999 is on a distinguished road
Check for large dangling ground wires.
I had similar issues when I had intake manifold off. I finally tracked it down to a ground wire I had not bolted back to the manifold. The fuel injectors needed that ground to fire but the cold start injector did not. So it would fire and run for a few seconds then die. Although mine was 22re v6 might have something similar.
sdb999 is offline   Reply With QuoteReply With Quote
Old 04-22-2016, 04:34 PM #6
Boggs Boggs is offline
Boggs is on a distinguished road
I had the same problem after removing my plenum. My maf had lost a ground somewhere. Your fuel pump gets power from ignition to start than the maf takes over the power supply to the fuel pump to keep it running with the circuit opening relay. Just my two cents. You can set a jumper in the diagnostic box to run the fuel pump. If it stays running while jumped something is not communicating. Worth a shot and maybe give you some direction.
Boggs is offline   Reply With QuoteReply With Quote
Old 04-22-2016, 04:39 PM #7
I could be mistaken but I believe if I remember it was te1 and f1 to run the fuel pump. but I would verify before trying
Old 04-22-2016, 04:49 PM #8
Correction. It's +b and fp
Old 11-19-2019, 10:39 PM #9
rsquaredatx rsquaredatx is offline
rsquaredatx is on a distinguished road
I see this is a really old thread, but I have the same issue. I replaced the tank, pump, FSU and fuel filter. (Old tank had rust in it from sitting for awhile after previous owner let it sit when it didn't start one day.)
I also used compressed air to blow the fuel lines out up to the rail.
1994 3.0 4x4
I jumped fuel pump to keep it running...and same behavior.
It will run as long as I spray starter/carb cleaner in it, so I assume I have spark.
Anyone else find anything else? This really has me stumped with 3 days of troubleshooting and $$ spent on new fuel system components.
Again...I know this is old, but it won't let me start a new thread because of low posting count.
Thanks!
1994 4Runner
v6
rsquaredatx is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 02:23 AM #10
Palatino Palatino is offline
Palatino is on a distinguished road
A head gasket job is very involved and it'd be hard to keep track of everything. Obviously something went wrong, probably when you put things back together. Check the vacuum hoses for cracks and make sure they are connected. A vacuum leak will give the engine too much air, but if you keep your foot on the gas pedal it might stay running since the computer would send a lot of fuel to compensate for the extra air. Check the fuel lines, since you said you smell fuel I'd assume they are good, so move on to the ignition components. Assuming your plugs are good, see if the wires are good. I'm saying this because my 98 had the same symptom after a valve cover job and the culprit ended up being the electrical connection on the ignition coils. I'm not sure about the ignition layout on your truck but it could be something as simple as that. Apparently the engine needs all 6 cylinders firing to stay running.
'98 T4R SR5 Green w/ 5.5 inch Rough Country lift mostly stock, 274k+ miles
Palatino is offline   Reply With QuoteReply With Quote
Starts then dies 4runnerinbaja 3rd gen T4Rs 15 01-27-2021 09:59 PM
86 starts and dies mike1979 Classic T4Rs 13 08-30-2010 08:46 PM
starts and dies dirtycj5 3rd gen T4Rs 4 02-02-2010 09:01 PM
88 4Runner starts then dies Avidangler Problems & Warranty Issues 1 04-10-2006 11:48 PM
Starts up , then Dies slice&dice Classic T4Rs 0 04-03-2006 12:52 AM
