Old 03-07-2012, 09:32 PM #1
jlewis74 jlewis74 is offline
jlewis74 is on a distinguished road
Couple of 1st Gen Questions????
1. I keep blowing the fuse for the brake lights, any idea what could cause this and how high of amp fuse can I use there?
2. I have not done a oil change since I got it, thinking of going synthetic would this be a good move? If so what weight should I use? I am in NC.
jlewis74 is offline   Reply With QuoteReply With Quote
Old 03-07-2012, 09:50 PM #2
GonOvr's Avatar
GonOvr GonOvr is offline
Real Name: Nate
GonOvr is on a distinguished road
GonOvr's Avatar
Real Name: Nate
Ok first off you have a bad wire somewhere, probably near or at the taillights. Your brake light power wire is going straight to ground somehow causing the fuse to blow. Putting a higher amp fuse will not fix the problem. It will only put more stress on the wire, causing it to heat up and melt down. Check your taillight bulb sockets for corrosion or bad wiring.
Synthetic oil is good but more than likely you will create or worsen current oil leaks. Synthetic is good for a new rebuild after break-in has been done. If you're hell bent on synthetic's, try a synthetic blend first and see if the leaks stay at bay and then switch to full synthetic if you still want. This is just my opinion, though. I run synthetic in everything i own top to bottom. Reason I do it is because I have seen the advantage first hand with my dad's trucking company.
Project 1-Ton Build Thread**SOLD**
Project 1-Ton Build Thread**Current Rig**
GonOvr is offline   Reply With QuoteReply With Quote
Old 03-07-2012, 10:15 PM #3
I do have a oil seep so dont want to make it worse, which kind of normal oil would you go with? I am planning on doing a full rebuild if it gets to the point of actually leaking, just dont see the need yet.
Old 03-07-2012, 10:15 PM #4
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
as far as the synthetic thing i would just use regular oil the 4runner 22re has been know to go 500,000 miles with just regular crude oil so there is really no benefit to synthetic other then the length of each oil change. and Nate is right sythetic in a old engine is just a waste of money but thats our opinion.
no its comm on for the older import trucks to have a non factory wiring harness made for towing, a common problem is the stupid splice connectors they use they are horrible and cause lots of issues, if you pull out the rear taillights you can see the harness for the lights if it looks cobbled you have a good place to start.
download the fsm and all your problems will be just that much easier to fix! we can always offer up stuff but the FSM will help when we cant be there to give you a helping hand.
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 03-08-2012, 01:26 AM #5
Thurlo76's Avatar
Thurlo76 Thurlo76 is offline
Thurlo76 is on a distinguished road
Thurlo76's Avatar
synthetic is the way to go after a rebuild!!! by far!!! i did it and o my.... its a beauty but i wouldnt switch it mid life like that.
1987 SR5 rebuilt 2.4ltr, custom front and rear bumpers, ball joint spacers, coil spring rear lift, 4.88 gears, 33x12.5x15 General Grabbers AT2's, bunch other goodies- SOLD.........
1997 SR5 4runner, 3.4, 5 speed, 4x4, 265/75/16's on Tacoma TRD rims, pretty stock....but not for long
Thurlo76 is offline   Reply With QuoteReply With Quote
Old 03-09-2012, 09:38 PM #6
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough
Moderator
fourwd1's Avatar
If you have a trailer hitch, check the trailer light wiring. That's the most common cause of rear lighting problems.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 03-28-2012, 08:22 AM #7
Got the brakes fixed, someone had tried to wire in a trailer lights and messed it all up. Took all the connectors off and taped them back up. I dont plan to tow with this so no need for it.
What kind of oil are you guys running and what weight? This is for a 175K miles 22RE.
1989 4-Runner
22RE
www.bassboattalk.com
Old 03-28-2012, 09:48 AM #8
Footofgod's Avatar
Footofgod Footofgod is offline
Footofgod is on a distinguished road
Footofgod's Avatar
Not sure if this is the best idea, but this is what I have done with older engines for years and it works. I run 20w-50 oil. After each oil change I add a quart of Lucas oil stabilizer. Doing this I have no leaks and the engine doesn't burn through oil. If I run 10w-30, my slow leak (rear main seal) comes right back and I burn through the oil in a month. Running the heavier weight oil has disadvantages. It makes for slower starts in cold weather and can create some sludge. That's why I do an oil change with 10w-30 twice a year. I have 240,000 on my Toy and 150,000 on my Mazda and both run great.
Originally Posted by dorton View Post
I wish I had a 2nd gen.
Originally Posted by BucknutBob View Post
I find myself wishing I had waited and picked up a 2nd Gen instead
Originally Posted by KidVermicious View Post
I want to convert my '85 to IFS.
Footofgod is offline   Reply With QuoteReply With Quote
A couple questions Markjr 3rd gen T4Rs 0 05-10-2011 09:41 AM
Couple of questions jay1981 3rd gen T4Rs 4 02-12-2011 05:32 PM
Couple questions! 2003Can4runner 4th Gen T4Rs 2 05-09-2010 12:11 PM
A couple of questions... inshore4runner 3rd gen T4Rs 6 11-09-2009 09:04 PM
couple questions 4Evr4RunN3R 3rd gen T4Rs 3 06-15-2008 03:10 PM
