Old 03-14-2012, 11:41 AM #1
OCMike's Avatar
OCMike OCMike is offline
OCMike is on a distinguished road
OCMike's Avatar
highway speed vibration
I've starting noticing a little vibration when I'm traveling at highway speeds and gently let off the accelerator. It goes away if I take my foot completely off though. Nothing rough, but I can feel something. Any idea what it might be? My runner is an automatic 4WD 3.slow.
'95 3.0 - OME shocks and springs - trail damage - Lots of stuff coming in the near future.
OCMike is offline   Reply With QuoteReply With Quote
Old 03-14-2012, 11:52 AM #2
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
Keep your foot off of the accelerator...??
Get your tires balanced.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 03-14-2012, 01:07 PM #3
GonOvr's Avatar
GonOvr GonOvr is offline
Real Name: Nate
GonOvr is on a distinguished road
GonOvr's Avatar
Real Name: Nate
Sounds like driveline float.
Check your driveline, pinion, and t-case output for play. Grease or replace as necessary.
Project 1-Ton Build Thread**SOLD**
Project 1-Ton Build Thread**Current Rig**
GonOvr is offline   Reply With QuoteReply With Quote
Old 03-14-2012, 01:21 PM #4
OCMike's Avatar
OCMike's Avatar
Tires are balanced. It only happens when I feather the accelerator.
Old 03-14-2012, 01:23 PM #5
OCMike's Avatar
OCMike's Avatar
Nate, I'll have my mechanic check that next time I take the truck in for service. Could that affect my mpg also? Have been noticing a drop of about 2 mpg over the last 4-5 months.
Old 03-14-2012, 01:34 PM #6
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
No that shouldn't effect the MPG. Just your tolerance and patience. If it gets worse, stop driving it. It could end up being catastrophic.
Old 03-14-2012, 02:12 PM #7
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
u joints?
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 03-14-2012, 03:41 PM #8
77'911 77'911 is offline
77'911 is on a distinguished road
We had the same, but it was a combo of issues. Costco improperly balanced the tires(don't have the proper centering mandrel for the balancer, unique to 4runners) which then had to be done by another co. I replaced the drive line mounts(engine and trans) which reduced the vibrations markedly. The last iteration that killed off any and all stability or vibration issues on the highway, was rebuilding the suspension with urethane bushings. The ones in the rear(ie rear lateral rod, rear control arms) really make quite a difference.
regards
77'911 is offline   Reply With QuoteReply With Quote
Steering Wheel Vibration at Highway Speed...revisited Thai Problems & Warranty Issues 74 12-18-2014 04:42 PM
2001 vibration at highway speed knucklebump General Discussions 0 09-23-2010 12:19 AM
08 4 runner vibration on highway only when cold bbumbles 4th Gen T4Rs 11 04-13-2009 12:14 PM
'04 A/C at highway speed ndgogal Problems & Warranty Issues 17 07-28-2004 01:12 PM
