Travolous
Old 05-01-2012, 11:32 PM #16
inscribed inscribed is offline
inscribed is on a distinguished road
Would the stock headers have not cleared? What modifications did you have to make to the 2UZ Tundra headers?
inscribed is offline   Reply With QuoteReply With Quote
Old 01-21-2013, 09:42 AM #17
Travolous Travolous is offline
Travolous is on a distinguished road
I wanted to post an update to this thread since it has been awhile. The motor has not gone in yet, and I decided to do a SAS while everything was out. The SAS is nearly complete and we will be dropping the engine in soon hopefully. I went with SKY Offroad SAS kit with a spring under design to make sure this truck is not really lifted a lot. I don't want a huge jacked up vehicle. I also want to run 33's only, so the spring under will make them look good without looking to little.
87 4Runner Build
1uz-fe w/ M112
SAS
Travolous is offline   Reply With QuoteReply With Quote
Old 01-21-2013, 09:43 AM #18
No headers would clear the steering arm of the 4runner. Two of the header tubes have to be cut and rewelded in different locations to not contact the steering arm. This is only on the drivers side.
87 4Runner Build
1uz-fe w/ M112
SAS
Old 01-21-2013, 09:49 AM #19
Adapter Plate Fitted
The adapter plate fit almost perfectly. There was one bolt hole that we will have to file a little bit. The program seems to be off just a hair on that bolt location. Also, Since I used the bellhousing bolts to install the adapter, I need to get another set of bellhousing bolts for the bellhousing to adapter I would recommend that for an $800 1uz to R150 Kit, it could come with bolts.
12/5/14 update: Talked to swap maker and he realized this was an issue and has since corrected it. Some of the bolt holes just had to be widened to fit the bolts. Should not be an issue with current production kits according to the seller (1uzfeswapkit.com)
1989 4Runner 1uzfe swap-adapter-plate-installed-jpg
87 4Runner Build
1uz-fe w/ M112
SAS
Old 01-22-2013, 07:28 PM #20
Jonny's Avatar
Jonny Jonny is offline
Real Name: John
Jonny is on a distinguished road
Jonny's Avatar
Real Name: John
subscribed...
on my "dream list"
1uz 5spd would be a fun toy on the trails
Jonny is offline   Reply With QuoteReply With Quote
Old 01-24-2013, 05:11 PM #21
Originally Posted by Jonny View Post
subscribed...
on my "dream list"
I think it's a much better option than throwing a 350 in the truck. If your going to do it, do it right and keep it all toyota!
I'm sending my lower intake manifold, water bridge, and fuel rails to a guy in Canada to fit an M112 blower. A 1uz is ok alone, but there is nothing beter than a boosted engine!
87 4Runner Build
1uz-fe w/ M112
SAS
Old 01-30-2013, 05:22 PM #22
1/30/13 Update:
Front Axle torn down, all parts ran through the Vat, sandblasted, and refinished and rebuilt tonight. I am also going over te entire frame with a wire wheel to remove any rust for refinishing. I also picked up a few parts this week include:
7M-GTE 315cc injectors for the M112
New gray shift boot for the interior
New 2nd Generation gray shift knobs for both sticks
Lexus SC400 oil pan that I will need to fit the 1UZ for the solid axle
New Inclinometer with dash pad in immaculate condition
Digital temp and compass rear view mirror
Pro Comp Rock Crawler Wheels
87 4Runner Build
1uz-fe w/ M112
SAS
Old 01-31-2013, 01:59 PM #23
Supercharging a 1UZ
For anybody who is thinking about supercharging a 1UZ I wanted to point out a few things you will need. The stock 1uz ECU can handle up to 12lbs of boost which is much more than you would be getting from the typical M90/M112 roots blower. There is a lot of talk about the M90, but for the money and time, you are wasting it all doing an M90. M112 is the only way to go for a roots blower on a 1uz. It should yield around 6lbs of boost at most without getting into the heavy costing items. What I am going with.
1. M112 from mustang cobra. Some people used lightning m112, which should be the same, but the snout length is different on certain m112 blowers and I know for sure the cobra will work.
2. Lower intake manfold to take the M112. I am having mine made by a guy in canada who is very good at this. I found him on lextreme. He has to moddify the lower intake, fuel rail, and front water bridge. The supercharger will fit nice and low on the motor.
3. Larger fuel injetors. Some have run the factory 1uz injectors, but I would never do that as if it ever leaned out to much, you have predonations and potential serious problems. I used 7mge non turbo supra injectors, which are 315cc in size
4. water/methanol kit. Heat is very bad, and without an intercooler system, the air needs to be cooled. Water/Meth is a cheap and reliable way to cool the air. I am, at this piont, going with an AEM kit.
In total, my supercharger cost will be roughly 1600 in parts, plus whatever my machinest charges to modify the M112 to work. All in all, a very worthwhile cost to add 100rwhp and such a sexy sound to your vehicle.
87 4Runner Build
1uz-fe w/ M112
SAS
Old 02-03-2013, 11:04 AM #24
M112
Picked up the M112 yesterday. Will have to grind off the inner lip underneath the supercharger so that it will mate with the modified lower intake manifold.
Also was emailed that marlin crawler had the R150f short throw shifters back in stock, so I ordered that as well. My shift was sloppy anyway and needed a new replacement.
From a guy who has previously installed an M62 (TRD supercharger) on a 3.4, this m112 is massive compared to that. I was shocked at how much bigger this supercharger is compared to the smaller TRD unit. I was getting 9lb of boost on that little M62 with the URD fuel upgrade kit, I'm hoping for 6-7lb on this unit with a 3.25" 6 rib pulley and AEM water/meth kit for boosted gasoline engines.
1989 4Runner 1uzfe swap-2013-02-03_09-55-01_818-jpg
87 4Runner Build
1uz-fe w/ M112
SAS
Old 02-04-2013, 06:07 PM #25
ajohnson's Avatar
ajohnson ajohnson is offline
ajohnson will become famous soon enough
ajohnson's Avatar
Holy crap. This thing is gonna be sick. When are you hoping to have it back together?
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
ajohnson is offline   Reply With QuoteReply With Quote
Old 02-04-2013, 06:29 PM #26
77'911 77'911 is offline
77'911 is on a distinguished road
One humble question, why can't you use an engine out of a late 80's or early 90's Cressida? I see loads of low km examples around BC.
regards
77'911 is offline   Reply With QuoteReply With Quote
Old 02-04-2013, 10:04 PM #27
regards
You could, not sure why you would want too though. There have been some supra 7mgte swaps, but I'm a bigger fan of v8s and supercharges more than smaller displacement and turbo.
87 4Runner Build
1uz-fe w/ M112
SAS
Old 02-04-2013, 10:04 PM #28
I'm hoping by end of July. It's a full restoration that I'm getting perfect inside and out though, so it could be longer. Currently the stages go as follows
1. Sas ( about 1/2 done)
2. Body work, paint, and upholstery
3. Engine install and tuning
87 4Runner Build
1uz-fe w/ M112
SAS
Old 02-08-2013, 04:33 PM #29
A couple of things I picked up:
New V6 Brake Calipers
HAWK Brake Pads
12 qts Redline Mt-90 for Transmission, transfer case, front/rear diffs
AEM water/methanol injection
285/75r16 MT MTZ
Procomp rock crawlers
87 4Runner Build
1uz-fe w/ M112
SAS
Old 02-09-2013, 12:28 AM #30
itgogitrev itgogitrev is offline
itgogitrev is on a distinguished road
Love this thread! Is is necessary to use the SC400 instrument cluster instead of the LS400... or even possibly the stock 4Runner cluster?
Just came across a LS400 with some rear end damage, gonna check to see if it's going to be worth getting as a donor.
~~Need 2nd gen FR fender in Sandalwood, PM me if you have one for sale!!!~~
itgogitrev is offline   Reply With QuoteReply With Quote
1989 4Runner 1UZ engine swap boscounderfoot Classic T4Rs 59 08-12-2021 07:32 PM
2000 limited custom, 1uzfe V8 SWAP Thread resurectedvikin 3rd gen T4Rs 24 12-18-2013 11:08 AM
1989 4Runner Need help! AR15 New Members 1 10-05-2011 02:37 AM
1UZFE Lexus V8 converstion tjb101084 3rd gen T4Rs 25 01-30-2011 02:11 PM
FS: 1989 4Runner 1st Gen!! ad1315 Classifieds - buy & sell (no commercial ads please) 4 09-02-2010 06:04 PM
