Originally Posted by Paradise87
I have an 87 4Runner and the fuel gauge only works for about 60 miles then it hits the bottom quickly. Any ideas of a problem? I would think that the sending unit either works or it doesnt but could be wrong.
I have been told the fuel tank can either be 14 or 17 gallons. Is there anyway to tell with out draining all the fuel?
Thanks for you help.
The gauge sending unit is a wire wound potentiometer (variable resistor).
The windings get corroded over time, creating dead spots. That's why it works a little then stops. Sometimes it will work/not work at various spots throughout the range.
If you pull the sending unit out and clean the windings with electrical contact cleaner, you may be able to get it working again.
As for tank size, run it down past E and fill it. If it takes 12-13 gallons to fill it, you have a 14 gallon tank. If it takes 15-16 you have a 17 gal tank.
'89 4Runner SR5 - stock
