Originally Posted by SV_Dude
It's too hard to determine where a leak is coming from when your starting platform is already dirty as heck. Spray some good degreaser all around your undercarraige. Then wash the whole area down and make it as clean as possible. Then take it for a short drive and look again for leaks. By doing this you should be able to spot the leak and the source pretty easily.
this is the easy way to find the leak.
my opinion is that you do a top down re gasket
start with valve covers then oil pan its cheap and easy to do so then once your engine is sealed back up then you can determine if the pig is leaking.
