Old 05-04-2012, 03:50 PM #1
coloradodave coloradodave is offline
coloradodave is on a distinguished road
Bouncing idle to a stall at a stop in the heat
Hey guys,
The ol' 94 has came over all sick since the weather has been getting warmer here in Colorado over the last month or so. At a stop the idle will drop to around 500 RPM then to 100-200 RPM up and down till it stalls. It was happening at first only when I had the AC on now its all the time since its been about over 70 Deg F.
I need to check the vacuum lines what else should I look into?
Dave
coloradodave is offline   Reply With QuoteReply With Quote
Old 05-04-2012, 05:54 PM #2
elcidsurfer's Avatar
elcidsurfer elcidsurfer is offline
elcidsurfer is on a distinguished road
The exact same thing was happening to me until I found the small hole in the plastic air tube running from the air filter to the intake at the throttle body.
Bought a new one put it on, problem solved.
The way I found the hole was to spray break cleaner (very flammable) over the engine lines. When the engine would rev high (burning the break cleaner) I would look where I sprayed and found the hole.
elcidsurfer is offline   Reply With QuoteReply With Quote
Old 05-04-2012, 08:02 PM #3
Ya buddy! I will start looking around tomo.
Rough Idle and sputtering = stall Deceptiwave 3rd gen T4Rs 9 10-13-2019 11:21 AM
idle drops when coming to stop Derek 4th Gen T4Rs 13 06-18-2012 08:52 AM
Vibration in V8 2004 at idle complete stop-changes when I turn wheel 4runnerfrenzy Problems & Warranty Issues 3 01-16-2011 01:01 AM
Checked everywhere: Vibration at idle complete stop- V8-changes when I turn the wheel 4runnerfrenzy 4th Gen T4Rs 2 11-22-2010 12:51 PM
