Originally Posted by awbartley
Hmm...I dont have one of those, only a keyed lock...
Ok, look and see if you have a cable that is under your dash where this handle should be. Maybe it got taken off. Also are your interior panels on or off? If off look and see if you see the cable in the right rear panel that goes into the cavity for the filler neck.
Maybe this handle was an option. I don't know. I'm sure someone with more knowledge that I will let you know. Im just wondering the the OP ever got into his. I noticed no reply from him.
