05-18-2012, 07:36 PM
Just joined the "Head Gasket Club"
It gave out today with an external leak. Noticed a puddle after I parked, and got under the truck with my flashlight to see some gurgling between the block and head.
I took it to the dealership, and they are going to fix it up for $1,800ish.
Head gaskets
Valve grind
Timing belt
Water pump.
I should be good to go for another 100,000 miles. It has exactly 200,000 on the clock now.
05-18-2012, 07:38 PM
Head gaskets
Valve grind
Timing belt
Water pump.
I feel your pain!
How are the other belts? Might have them replace all the belts while they have it torn apart.
05-18-2012, 07:58 PM
Originally Posted by RiFF RaFF
I feel your pain!
Good idea.
I'll ask them on Monday.
05-18-2012, 08:14 PM
I would not pay that much, you could get new head with new cam for $500 or so then pay someone $500 tops to put it on. That is for the 22RE not sure which motor you have.
1989 4-Runner
22RE
www.bassboattalk.com
05-18-2012, 09:00 PM
I have the 3.0.
For some repairs I order to use Toyota techs and Toyota parts. In the long run it's only a little more expensive.
05-18-2012, 10:02 PM
If the head gasket has not been replaced before wonder if it would still be covered under the Toyota's 'head gasket recall'. It has been many years ago when my 90 T4R headgasket had to be replaced, to my surprise, at no cost to me. Probly a long shot for $1800 would not hurt to ask?
Dave
'The problem with engaging in useless activity is never knowing when you are done'
1990 T4r, SR5, Auto, 4X4
05-18-2012, 10:21 PM
I had them run the VIN at the dealership before I bought it.
No open recalls.
05-21-2012, 08:59 AM
Yesterday I looked closely at my oil leaks. I hope I will be able to degrease everything and then pinpoint them. What looks like a bad rear main seal leak may be a bad head gasket leak. Now to set the record straight, there are two head gaskets, right and left on the V-6, aren't there? I see a leak from the front end of the right gasket and suspect a rear leak from the same one if that is true.
05-21-2012, 09:06 AM
Talk to your local parts stores and see if they can recommend a good local mechanic. You'll pay less, and hopefully there is someone very qualified for your situation. For example, in Madison I could recommend an ASE certified mechanic that used to work at a Toyota dealership. You'd pay half the price, and get the same quality.
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
05-21-2012, 09:12 AM
Don't do it!!!! 1800 is a RIP OFF. The water pump is 100, timing belt is 20ish, head gaskets aren't that expensive either. its only a couple hour job as far as labor.
'92 4runner 4x4
Rancho 9k's, Maxxis Mudds 32/10.5/15 3.56's | 2 10
Cobalts w/ an 800w amp, MA Audio speakers w/ 300w amp,
Soon to come - 3" lift, 35's on 4.88s, 350 swap.
05-21-2012, 11:08 AM
Well, Im sure its under the knife already.
I know the parts are cheap. The labor is the expensive part.
I might have saved $400ish by using "Joe's Garage"............Meh..........i dont have the luxury of time to shop around for several days.
05-21-2012, 12:07 PM
Real Name: Cory
Real Name: Cory
$1800 is such a rip. You can get a BRAND NEW 3vze for 1500ish.
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
05-21-2012, 12:20 PM
If I mail you $1500 can I drive my 4Runner tomorrow?
Oh, and I'll need a rental car for the day while I wait. Is that included?
05-21-2012, 01:21 PM
dude look around. labor MAX is 400-500. parts max is 250 or so. i drive a 3.0, ive worked on it.. you can do the belt & pump yourself, just unbolt & take off the fan, radiator hose, pulleys, & cover... you can do both of them in less than an.hour, all you need to do is mark your timing belt & the engine, so you can put it back on right & get the tension out of it...
'92 4runner 4x4
05-21-2012, 02:38 PM
I wish I had time to do it myself.
Being self-employed kinda sucks since I work 7 days a week, from when I get up in the morning, till I go to bed at night.
I ain't a-*****'n though.
ETA: I would probably have more time in my day if I stopped logging in here and drooling on all the T4Rs.
