Old 07-09-2012, 03:33 PM #1
jay4runner jay4runner is offline
jay4runner is on a distinguished road
1990 4Runner - Steering linkages repairs
My 1990 4wd, 4cyl 4Runner has over 350k km. Still runs great. Was advised the other day during an oil change that the RF inner/outer tie rods, RF idler arm, LF upper ball joint and all shocks need replacing.
I have done some reading on the internet (including this site) and have a bit of a plan, however, would appreciate some further advice.
For the tie rods I found a toyota part that seems to be the complete inner/outer tie rod assembly (45460-39505). Would it be better to purchase this entire assembly? Also, if I replace on the right side is it advisable to also replace on the left (so that both sides are updated)? Is this a fairly easy replacement - can one with basic mechanical skills/tools likely complete?
For the idler arm there is quite a range of prices. My Toyota dealer quoted me $445 for the part. It appears that I can get the genuine toyota part online (Toyotapartszone) for $200. Then I see that you can get other brand ones such as the Sankai for $128 (Partsgeek) which is evidently the company that makes the oem? I have also seen some comment that perhaps one can just replace the bushings on the original idler arm - does this make it as good as new? And with the idler arm repair are you best to do both sides? Is this a fairly easy replacement - can one with basic mechanical skills/tools likely complete?
For the upper ball joint should I stick with original toyota parts? Again, am I best to do both sides? Is this a fairly easy replacement - can one with basic mechanical skills/tools likely complete?
Any recommendations on particular shocks?
Perhaps most importantly are there any other key parts/components that I should probably be looking to replace at the same time?
Thank you for your comments/advice.
jay4runner is offline   Reply With QuoteReply With Quote
1990 , ball joint , idler arm , shocks , tie rod
1990 steering needs help Aquatic Escape Classic T4Rs 0 01-26-2012 02:39 AM
1990 TOYOTA 4RUNNER Steering Gear hjalti_gto Classic T4Rs 1 10-25-2011 06:04 AM
Help Needed on various 4Runner Maintenance and Repairs (WashDC/No VA/MD area) tsk General Discussions 0 06-19-2011 10:57 PM
1990 4cyl steering makes a grinding sound when cranked. canadacrazy69 Classic T4Rs 5 01-20-2011 10:15 PM
Is it worth it? 1992 4runner repairs needed zjccarter New Members 5 12-11-2010 06:01 PM
