Old 07-15-2012, 11:20 AM #1
BearRock BearRock is offline
BearRock is on a distinguished road
22RE Resurrection - What's missing?
86 22RE needs to run again, been parked 7 years. Some parts removed by the previous owner and in a box, and may be some missing. So, the trivia contest begins......
On the back of the EFI air intake there is a 2 bolt flange, what goes here?
22RE Resurrection - What's missing?-placerville-20120715-00095-jpg
And, on the firewall next to the Brake Booster, there are several pipes the are not connected. The hoses, and what they would be connected to is not clear. 22RE Resurrection - What's missing?-placerville-20120715-00092-jpg
22RE Resurrection - What's missing?-placerville-20120715-00093-jpg
I have the Toyota factory repair manual (all 750 pages) - but I need some clues as to where to look.
Thanks
BearRock is offline   Reply With QuoteReply With Quote
Old 07-15-2012, 07:19 PM #2
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
On the first pic, there is a part of the EGR system that goes there. I would pull ALL of the egr junk out and install cover plates.
The other pics are coolant lines. Check out the FSM in the cooling section for the coolant diagrams.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 07-16-2012, 01:58 AM #3
SV Dude, thanks for the quick reply.
I checked the FSM, and it does not have any diagrams or pictures other than replacement of the water pump, thermostat.
Do I just need a hose between the 2 pipes on the left, and the 2 on the right? That seems possible on the left, and the hose on the right looks like it may have been cut short.
Does any one have a picture of what it should look like?
I'll try visiting the dealership to see if they have a parts diagram, I don't know how far back they go.
As for the EGR component, I'm sympathetic to that solution. I will have to get this California Smog certified to get it registered and back on the road. So, that is the final hurdle to getting this project done.
Making progress, today I drained the gas tank, replaced the fuel filter (fun finding that one, a true braille replacement, all by feel, never saw it), changed the oil and filter, replaced the alternator, cap, rotor, plugs and plug wires. Previously I replaced a bent front A-arm, which is why it ended up being parked. Next, radiator flush, reinstall cleaned up throttle body and hoses. Then I'll see if the fuel pump works and if I can get enough gas through the injectors to get it to start.......
Old 07-16-2012, 03:04 AM #4
hoe_nah hoe_nah is offline
hoe_nah is on a distinguished road
The pipe on the left side coming out of the firewall is for the heater core and to the right of that should be a valve thingy I believe they should all be hooked up but you could leave the heater core open..
hoe_nah is offline   Reply With QuoteReply With Quote
Old 07-16-2012, 03:46 AM #5
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
I've got an '86 22re, I'll get you pics of the heater hoses on the firewall in the morning. Anything else you need to look at?
KidVermicious is offline   Reply With QuoteReply With Quote
Old 07-16-2012, 10:43 AM #6
combatmedic combatmedic is offline
Banned
combatmedic is on a distinguished road
Banned
Please keep us updated, I want to know if she comes back to life.
combatmedic is offline   Reply With QuoteReply With Quote
Old 07-16-2012, 12:21 PM #7
Additional Pictures
KidVermicious,
A picture of the fitting on the back of the EFI enclosure, so I can see how the EGR valve connects would be helpful. The EGR is bolted on the back end of the block.
thanks
Old 07-16-2012, 12:34 PM #8
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
KidVermicious,
thanks
that should be a crossover pipe. id just plug it.
nevada is offline   Reply With QuoteReply With Quote
Old 07-16-2012, 12:37 PM #9
Real Name: Kevin
Real Name: Kevin
These help?
22re , rebuild
22re missing exhaust bolt please HELP! JoeMegeddon Classic T4Rs 5 01-30-2016 10:06 PM
Supra 22re AFM for 22RE Wreel For Sale: T4R Items 0 05-01-2012 02:53 PM
can a 22RE block be used to rebuilt 22RE-T? Black_TurboSR5 Classic T4Rs 3 11-17-2010 10:50 PM
Is something missing on this T4R? T4Rnewb 3rd gen T4Rs 16 10-25-2010 02:40 PM
