Old 07-20-2005, 05:08 PM #1
Aero Aero is offline
Aero is an unknown quantity at this point
Warning Lights????
So I"m bombing down the highway in my 1990 3.0 and I look down to see 3 warning lights! The Brake(!), the Battery Symbol, and the A/T Temp light????????? After pulling over and checking the basics, I decide to keep driving. The lights eventually go out...but now they come on periodically. Any ideas on what is causing this? My first guess is a loose harness or a short somewhere...anybody have any experience with this? Should I be taking the truck to get a diagnostic?
Any help is greatly appreciated,
Aero
1990, 3.0 V6, Auto, 31' BFG
2000 SR5 4WD Auto w Diff Lock
Aero is offline   Reply With QuoteReply With Quote
Old 07-20-2005, 08:35 PM #2
Sidney Sidney is offline
Sidney is an unknown quantity at this point
If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver.
For carbon brushes R&R:
http://www.4x4wire.com/toyota/mainte...nator_brushes/ http://www.toyotaoffroad.net/afertig...torbrushes.htm
http://perso.wanadoo.fr/adherence.4x...nateur_kzj.htm
http://www.automotiveforums.com/vbul...d.php?t=166525
http://www.toyotanation.com/forum/sh...270&forumid=10
http://www.pirate4x4.com/forum/showt...r+brush+holder
http://www.bitwalla.com/cruisers/art...lternator.html
http://www.barneymc.com/toy_root/tec...c/altrnatr.htm
For decoding the dashboard lights:
http://www.powerbase-auto.co.uk/alternator_faults.htm
http://members.1stconnect.com/anozir...alternator.htm
Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles.
Toyota alternator Brushes with holder:
Toyota # 27370-35060=$29 CDN
Honda # 31105-PZ1-003
Metro # 39-82003 (www.metroautoinc.com ,Pomona,California)
Unknown brand name # F4019-53035
Alternator brush only (qty:1 brush unless otherwise stated):
AC Delco # E724
AC Delco # E731 (side wire and concave tip)
Ace Electric # DA-61 (brush only),S-5367 (brush holder)
Beck Arnley # 178-1669 (side wire and concave tip)
Beck Arnley # 178-1376
Borg Warner # X580 (side wire and concave tip)
Canadian Tire # 19-2050-6=$4.49/pair
Daihatsu # 27370-87302-000
Daihatsu # 27371-63020-000
Daihatsu # 27371-87501-000
Daihatsu # 27371-70300-000
Echlin # E601=$8.16 CDN/pair (UAP/NAPA)
Echlin # ECHE601
Echlin # EC480
Echlin # ECHE480
GP Sorensen # 255047 (side wire and concave tip)
GM # 94123056
GM # 96054118
Honda # 31144-PD1-004=$9.72
Honda # 31144-PD1-0040
Honda # 31144-PD1-0030
Honda # 31150-PR7-A01
Honda # 31150-PTO-003
Hino Industries # 021660-0390
Hino Industries # 021660-0510
Isuzu # 8-94123-056-0
Isuzu # 8-97032-308-0
Isuzu # 8-97032-310-0
Mazda # 021660-0390
Mazda # 021660-0510
Mazda # KL47-18-W75
Metro # 38-82001(side wire concave tip) (www.metroautoinc.com ,Pomona,California)
Mileage Plus # E601SB
Mitsubishi # MD604474
Mitsubishi # 21660-0510
Niehoff # WA571 (side wire and concave tip)
NipponDenso # 021660-0390
NipponDenso # 021660-0510
Standard # JX-116 (side wire and concave tip)
Subaru # 021660-0390
Subaru # 021660-0510
Suzuki # 31631-82610
Suzuki # 31656-82611
Suzuki # 021660-0510
Toyota # 27370-42010
Toyota # 27370-75060
Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip)
Toyota # 27371-70300=$5.20 (9105-9511)
Toyota # 27371-76004-71
UAP/NAPA # MPEE601SB
Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire)
Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN)
Specifications:
Length=15 mm
Width=7 mm
Thickness=5 mm
Lead length=49 mm
These Honda alternators are the same except the pulley must be swapped:
1986-89 Honda Accord (Carb),the EFI can be used but the voltage reg must be swapped
1990-93 Acura Integra
15 Toyota (NipponDenso now called Denso) starter repair sites:
http://www.off-road.com/4x4web/toyota/tech/starter/ -
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
http://char.tuiasi.ro/vw/reality/rog...s/Starter.html
http://yotarepair.com/startercontacts.html
http://www.toyotaoffroad.net/afertig...rterrepair.htm
http://www.4x4wire.com/toyota/maintenance/starter/
http://www.yotatech.com/~corey/tech/...r/haveblue.htm
http://www.sleeoffroad.com/technical...er_rebuild.htm
http://www.startercontacts.com/install.htm
http://www.startercontacts.com/image...ded%20view.jpg
http://www.colorado4x4.net/tech/star..._contacts.html
http://www.barneymc.com/toy_root/techneek/starter.htm
http://perso.wanadoo.fr/adherence.4x4/start_bj.htm
http://www.automotiveforums.com/vbul...d.php?t=166530
http://www.toyotanation.com/forum/sh...312&forumid=10
http://www.toyotanation.com/showthre...312&forumid=10
Starter contact kits (8mm ID hole):
Ace Electric # S-5263 (only two contacts)
Ace Electric # S-5264 (only two contacts)
Metro # 66-82104 (only two contacts) (www.metroautoinc.com ,Pomona,California)
Toyota # 28226-72010/80 (battery side)(also1KZTE-2LT-1KZT)
Toyota # 28226-72080 (8808-9108)
Toyota # 28226-16130 (9108-9308)
Toyota # 28226-55050 (9308-9511)
Toyota # 28226-70040 (9308-9511)
Toyota # 28226-72040 (motor side if needed)
Toyota # 28226-72010 (8808-9511)
Toyota # 28226-74070 (9108-9511)
For others besides 22R series:
Toyota # 28226-54220 (motor side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130,LN108,112,85..4FC)
Toyota # 28226-54250 (Diesel Surf 2.4TD, contains a new end cover and gasket)
Toyota # 28226-54320 (battery side) (2LTE, 3L..LN13# IKZTE, 2L#, KZN130, LN108,112,85..4FC,3B-1HZ-BJ73-HZJ7#-1KZT-KZJ70)
Toyota # 28226-17030 (battery side) (1H#-HDJ80-HZJ80)
Toyota # 28226-56250 (battery side) (3B-1HZ-1PZ-PZJ7#)
Starter contacts only (8mm ID hole):
Ace Electric # S-5231
Ace Electric # S-5293 (crescent moon shape)
Ace Electric # S-5295 (crescent moon shape)
Metro # 66-82106 (www.metroautoinc.com ,Pomona,California)
Tons more at:
http://www.metroautoinc.com/PDF%20Fi...%20Contact.pdf
Wilson
Sidney is offline   Reply With QuoteReply With Quote
Old 07-21-2005, 04:45 PM #3
Thank you!
Would this cause these lights to come on intermitently? It seems to be only at higher speeds...is this typical?
Also any hints or suggestions on getting the alternator out....do I have to remove the distributer?
Thanks again for all your help.
Aero
Old 07-25-2005, 10:01 AM #4
yotatilla yotatilla is offline
yotatilla is an unknown quantity at this point
I have a similar problem, if oyu could call it that. When on the highway, my check engine light comes on and then goes off within 10 seconds. It continues to just come on spuratically as long as I am on the highway. As for changing the alternator, it is very easy. The alternator is located on the driver side on mine, which is a 22RE. This is pretty much the same for every vehicle. The alternator on my chevelle come out the same way. There is a bolt on the top of the alternator used to tighten it the alternator to the bracket. Take that out completely. Now you should be able to move the alternator from side to side, allowing you to take the belt off of the pulley. There will be 2 wires in the back. Remove them, one will be a plug and the other will be under a nut, 9 mil if i recall right. Underneath the alternator there is a long bolt that goes the entire length of the alternator. Put a wrench on the front and a socket on the back and remove it. Now the alternator will just fall out. It may be kinda tricky getting it completely out of the engine bay, but just wiggle it around. I believe it comes out the top the easiest. My advise on the temp lights and whatnot is to go to your local autozone and ask to borrow a codescanner. They will most likely have one, and if not, they can get it for you. I hope that this helped, Sam.
2 1986 4Runners+
1 solid Axle+
2 transfercases+
4 35x14.5 TSL's+
2 Aussie Lockers+
1 Marlin SAS kit=
UBER 4RUNNER
yotatilla is offline   Reply With QuoteReply With Quote
Old 07-25-2005, 07:34 PM #5
celica celica is offline
Registered User
celica is an unknown quantity at this point
Registered User
You don't need a code scanner to read the codes in the computer. You can use a paper clip and bride the two inputs as indicated unter the hood. There will be label telling you which ones to bridge. This will make the check engine light flash the codes out. All the Haynes & Chilton books will tell you the codes. Sounds like alternator/battery issues to me.
celica is offline   Reply With QuoteReply With Quote
Warning lights on! HELP!!! David D 3rd gen T4Rs 17 10-27-2012 06:14 PM
Reset Warning Lights phillyd2 Problems & Warranty Issues 2 01-29-2009 10:58 AM
Warning lights! Lots of 'em!! biskit 4th Gen T4Rs 4 01-06-2008 01:10 PM
Dash warning lights lit for apparently no reason... UoD Problems & Warranty Issues 2 02-13-2006 09:00 PM
