Old 08-15-2012, 11:06 PM #1
JRR JRR is offline
JRR is on a distinguished road
JRR JRR is offline
Leaking Coolant
Bought my '93 4runner few months ago and I'm pretty new to cars. I knew when I bought it that the cooling system was leaking coolant but didn't know where. I would like to fix this problem so I can take her out more than I have been. How do I go about checking where the leak is? All I know is that the engine block and other parts on the passenger's side are wetter than the driver's side so I'm inclined to think it's over there.
JRR is offline   Reply With QuoteReply With Quote
Old 08-15-2012, 11:08 PM #2
ToyoTech's Avatar
ToyoTech ToyoTech is offline
ToyoTech is on a distinguished road
ToyoTech's Avatar
is it a 3.0 v6?
if it is pissing out. you can open the cap up, start the truck up. fill the coolant system with water and see where its coming out from. i dont think theres any coolant lines on the passenger side. the 3.0 v6 are known for blown headgaskets
ToyoTech is offline   Reply With QuoteReply With Quote
Old 08-15-2012, 11:14 PM #3
JRR JRR is offline
JRR JRR is offline
Yeah, it's a 3.0 V6
Can I just put some water in or do I need to do anything before that?
Old 08-15-2012, 11:47 PM #4
hoe_nah hoe_nah is offline
hoe_nah is on a distinguished road
How bad is the leak? Wash down the motor as much as possible, fill up with coolant run with Hood open and inspect for leaks. How does the current coolant look? Milkshake?
hoe_nah is offline   Reply With QuoteReply With Quote
Old 08-16-2012, 09:04 AM #5
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Originally Posted by JRR View Post
Yeah, it's a 3.0 V6
Yes, you can put water in. But first, I'd drain the existing coolant and do as hoenah suggested, see if there's any oil in it. And look for thick white goo on the bottom of your oil cap. Those are both common signs of headgasket failure.
Failing that, scrub your engine compartment down real good, let it dry, and then run the engine and watch for leaks.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 08-16-2012, 09:46 AM #6
combatmedic combatmedic is offline
Banned
combatmedic is on a distinguished road
Banned
With that being said, don't drive it until you know for sure what's going on. Driving with a bad HG is a NO NO.
The HG is a barrier to keep the oil/coolant from mixing together. When it fails, coolant gets in the oil, and oil gets in the coolant. It's pretty nasty.
combatmedic is offline   Reply With QuoteReply With Quote
Old 08-16-2012, 10:02 AM #7
JRR JRR is offline
JRR JRR is offline
No white goo under the oil cap but the coolant reservoir looks like mud. I'll wash everything down and see how it goes. Thanks guys.
coolant , cooling , cooling system , leak , leaking coolant
water leaking or coolant jasmine366 Classic T4Rs 19 03-15-2013 07:59 PM
leaking coolant hardlines 2fas2c Classic T4Rs 2 05-19-2011 10:06 PM
Help! - Coolant Leaking into the Engine tsk General Discussions 0 02-07-2011 01:59 AM
Leaking Coolant? simple 4th Gen T4Rs 6 02-06-2011 11:55 PM
Coolant Leaking 94 4wd 3.0 l HELLLLLLP! Robeo01 Problems & Warranty Issues 4 11-17-2010 10:00 PM
