02-05-2013, 04:07 AM
#61
Real Name: Kevin
Real Name: Kevin
Originally Posted by thatoneguy
Thinkin' of going 33's for a little while, to see if I really wanna build the runner before I spend lots of money I wouldn't get back.
The ideas that hit my head were narrow 33's, regear to 4.88's - probably buying a locked 4.88 rear third used, BJ spacers in the front, new lift springs in the back.
Anyone ran a setup like this, or a similar one? I honestly love the way 33's look, on anything.
I ran 255/85s and 5.29 on the '86 (auto), and I'm going to run the same tires and 5.29 on my '85 (manual). 4.88 and 5.29 is only a difference of a couple hundred RPM at 75 mph, and I dunno about you but with the 22RE I'll trade that slight mpg hit for better climbing ability any day. And it'll give you wiggle room to try 35s down the road, if the bug bites you .
You'll probably rub a bit on the back of the fender liner at full stuff with 33s and just ball joint spacers, I did. A little trimming and pounding took care of that.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
02-13-2013, 01:58 AM
#62
Here is my "rig"
91 SR5
3.0/auto
factory 4.10 gears
open diffs
factory ride height
32x11.5 Swamper SSR on factory 15" wheels
new CVs
Warn manual hubs
Hopeful for exhaust and bumpers soon
02-24-2013, 06:51 PM
#63
Really Saggin!!!!
1994 four runner with tons of rear sag. Bout time to fix this and have researched a fair amount about possible solutions. Being on a college student budget I am thinking of Moog C255 replacement springs. Eventually I may want to add coil spacers on top of those down the road. With the new Moog springs in the rear will I be able to fit 33X10.50's on it with little to no rubbing? Anyone have any pictures of this upgrade? Also, by no means am I a master mechanic, but feel confident enough to tackle this by myself. Anyone have a link or any tips to help with the installation process?
Thanks boys,
Grenda
02-25-2013, 10:59 PM
#64
Real Name: Lee
Real Name: Lee
Tire and wheel size question
Hey everyone, I have a tire and wheel size question. I currently have stock 95 Toyota alloy wheels, (I think they're 15x7's?) with 31x10.50 AT's. Anyways, I am going to go to 33x12.50 MT's and I would like to go with steel wheels. For the 12.50 width, is it better to have 8" or 10" wide wheels? I found a good deal on some 15x10's and picked them up. I dont want to spend the dough to have them mounted up only to discover that I should've gone with 15x8's. Any advice would be helpful, and thanks!
1995 4Runner Cali spec 3.slow/auto, SAS'd and leafs out back..the jury is still out on this! 35x12.50 Cooper STT Pro's, Viair 450, K&N filter, ARB with Warn VR8000, ARB locker, etc. etc.
02-26-2013, 12:58 AM
#65
Grenda, my 91 T4R has Moog aftermarket coils and cheapy stock length shocks. It rolls on 15x7 factory wheels and 32x11.50 SSRs. They fit fine and don't rub unless I am turning hard at a weird angle offroad. I would think 33x10.50s would be fine also. Most 33x10.50 radials will be right about the same height as my 32s. The narrower width may also help you out there.
FormerJeeper, I can't help you out much. I prefer a 12.50 tire on an 8" wide wheel. 10" wide wheels really don't do it for me but it will work. I like the 8" wheels for a 12.50 tire because there is less of a chance of popping a bead offroad (my personal observations and opinion). For full tire pressure on the road, it would be fine. Plus, I just like the look of a tire with a balooned sidewall. A wide wheel gives the tire more of a blocky profile.
02-26-2013, 03:08 AM
#66
Real Name: Cory
Real Name: Cory
Thanks boys,
Grenda
You can fit 33s with some hammering/pounding. If you plan to lift it in the future (such as spacers), do it right the first time. Search around for fj80 landcruiser coil swaps for 2nd gen 4runners.
I'm running them on mine and I am around 3.5" of lift now that they are settled, and they flex like a mofo.
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
02-26-2013, 03:12 AM
#67
I'm buying a set of fj80 coils in a few days. With all that lift in the back what did you do to the front of the 4runner?
02-26-2013, 03:26 AM
#68
Real Name: Cory
Real Name: Cory
Ball joint spacers, diff drop, and slight torsion bar crank (not enough to really feel though)
This is it sitting on 31s
02-26-2013, 02:26 PM
#69
Can anyone give a link or video on how to install the fj80 coils and the ball joint spacers?
Thanks
02-27-2013, 05:35 AM
#70
here comes my 94 stock lift with 31X10.5 pickin up the rear of the pack. Plan on getting a moderate lift and at least put 33 mud slingers and different wheels
JY4RUNNER
02-27-2013, 05:41 AM
#71
Real Name: Kevin
Real Name: Kevin
12.5s are going to be very wide on an 8" wheel. Not impossible, but if you have the room I'd go with the 10" wheel. Whether or not you have the room depends on the backspace of the wheel you're looking at. If you can, I'd look into having the shop test mount them before you buy them.
02-28-2013, 03:12 AM
#72
Real Name: Cory
Real Name: Cory
Thanks
It's pretty straight forward. Just rent a spring compressor from autozone.
You will need to grind your upper control arms a bit for BJ spacers. Google will solve all your questions. There is TONS of write-ups about this.
02-28-2013, 08:17 PM
#73
Real Name: Kevin
Real Name: Kevin
Stock (saggy) height with 30's:
Dakar/OME lift installed, with 5" shackles in front and 6" shackles in rear:
255/85r16s on. Oodles of room.
03-10-2013, 08:41 PM
#74
Got my fj80 springs in and it lifted the back end just shy of 5". It looks much better. Have not done the shocks yet and am assuming my Rancho 251D shocks are maxed out and therefore not being utilized? Any suggestions on a reasonablly priced shock that will make the ride a lot smooth because right now it is very rough. Below are some pics...Thanks for all the help yall.
03-12-2013, 10:51 AM
#75
hey grenda, what size tire are u running? good looking rig.
