Parasitic Draw Short , am2 fuse
I picked up a 1993 4runner, Battery dead over night, Did the parasitic draw test , determined it was the am2 fuse. traced the wire, white with red stripe to the connection clip under dash that goes to ignition switch, this is the wire coming from the am2 fuse, tested it ( verified ) after I disconnected the clip hoping it was the ignition switch, tested the draw and its still there. What does this wire go to , I know it feeds the ignition switch ( key ) but it feeds more than that. Any ideas !!
Thanks for any help you can offer .
