Old 09-21-2012, 03:48 PM #1
Kev4runner Kev4runner is offline
Kev4runner is on a distinguished road
gas tank removal? 1990 4runner
anyone know how to remove a gas tank off a 1990 4runner?
pics and info pls!
Kev4runner is offline   Reply With QuoteReply With Quote
Old 09-21-2012, 04:10 PM #2
BucknutBob's Avatar
BucknutBob BucknutBob is offline
BucknutBob is on a distinguished road
BucknutBob's Avatar
This is on the assumption that the '90 is the same as a '95:
It helps to drain it first by the bottom plug. Get a floor jack and wide block(s) to support tank. Toughest part is removing the filler and vent tubes, reached by removing the cover plate in the fenderwell. The engine feed line is on top, reached through the access hole under the rear seat--this is also where you disconnect the wiring harness, and bend open any metal clips that hold the wires (these will bend back when reassembled). The return and EVAP hoses are also on top, but towards the middle of the truck--release clamps blind and pull hoses off from near driveshaft. Bolts front and rear hold both tank and shield. Tank must slide forward slightly before lowering all the way, and check for add'l metal wire clips running toward front of tank--bend out of way, or tank will hang up on sending unit wire. Lower away. Like the manuals always say, installation is the reverse of removal (LOL). I hope I didn't forget anything. Best of luck!
Former owner of four Runners: three 2nd Gens and one 1st Gen. Idle for now, but will be back in one again before too long.
BucknutBob is offline   Reply With QuoteReply With Quote
Old 09-21-2012, 04:25 PM #3
thank you!! good thing you msged, thought that no one would cos, i tried searching on how to remove it and there was no thread about it
Old 09-21-2012, 08:23 PM #4
Pyroboy's Avatar
Pyroboy Pyroboy is offline
Pyroboy is on a distinguished road
Pyroboy's Avatar
Look for a Haynes manual for your truck. They are well-illustrated and have step-by-step instructions for almost anything you will work on. Canadian Tire sells them.
Toyota Repair Manual covering Pick-ups ('79-'95), 4Runner ('84-'95), and SR5 Pick-up ('79-'95) (excludes diesel engine, T100 or Tacoma information)
'89 4Runner Special Edition, Original Owner
22RE, 5-Spd, SAS, Lockers, Duals
Toyota Fiberglass panels
Pyroboy is offline   Reply With QuoteReply With Quote
Old 09-21-2012, 09:18 PM #5
BucknutBob's Avatar
BucknutBob's Avatar
It would figure--I comment on removing a gas tank, so my truck decides to develop a mystery fuel leak and probably force me to remove my own! Judging from where it's wet on top, it seems to be seeping out of the sending unit gasket. I'm really starting to dislike my truck. (note steam coming out of ears...)
Old 09-22-2012, 01:30 PM #6
77'911 77'911 is offline
77'911 is on a distinguished road
tank drop
3VZE Fuel Pump replacement(in process), pics
This link might help. I posted this a while back when replacing the fuel pump, and had to drop the tank.
regards
77'911 is offline   Reply With QuoteReply With Quote
Old 09-22-2012, 01:36 PM #7
sending unit gasket/ fuel pump
Probably needs the sending unit gasket in the pick. You might pick one up at the dealer, toyota upgraded this part. Definitely an improvement over the original.
Old 09-08-2014, 04:49 AM #8
TechOp's Avatar
TechOp TechOp is offline
TechOp is on a distinguished road
TechOp's Avatar
Dam rusty ass screws on them gas tanks
Instead of starting a new thread I figured I just pig this one. I wish I could have found it BEFORE I started!!! Had a gas leak on my 93 and couldnt tell where it was coming from but down the frame and tank.
After spending 3 hours trying to get rusty screws out the tank cover. I made a new best friend. DREMEL
THKS 77'911
gas tank removal? 1990 4runner-img_0163-jpg  gas tank removal? 1990 4runner-img_0157-jpg
With my 93 Stick 3.slow
No dishonor shall come to this house!
TechOp is offline   Reply With QuoteReply With Quote
Old 09-08-2014, 04:52 AM #9
TechOp's Avatar
TechOp's Avatar
Went top side for the glory hole and found my dam leak. 2 cracks in the rusty fuel line
gas tank removal? 1990 4runner-img_0166-jpg
Old 12-22-2020, 05:03 PM #10
Edweller Edweller is offline
Edweller is on a distinguished road
Dude thank you so much. I got everything except the under the rear seat. You just saved me a ton of figuring out.
Edweller is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 06:56 PM #11
Howitzer's Avatar
Howitzer Howitzer is offline
Howitzer is on a distinguished road
Howitzer's Avatar
Before I had a Dremel tool, I just dusted the edge of a riffler file to create a slot for a slotted screwdriver for those pesky Phillips 2 screws on top of the sending unit or on top of the fuel pump assembly. Coat everything in grease when you re-install (if yo are installing new) ive never seen an oil leaky engine rust, same goes with fuel lines. If it leaks fuel, it'll wash the grease off anyhow so no worries about it masking any leaks. if you can run the tank as low as you can, go for it, I just got under it an used a 3/8" impact and let the tank drop onto my chest and then rolled over with it and placed it on the ground
87 4Runner Diesel swap in progress- stay tuned for writeup
If Nobody From The Future Comes And Stops You, How Bad Of A Decision Can It Really Be?
Howitzer is offline   Reply With QuoteReply With Quote
Old 12-27-2020, 10:46 AM #12
damncajun's Avatar
damncajun damncajun is offline
damncajun is on a distinguished road
damncajun's Avatar
I have a 9gal tank on my 86 if someone would like to trade for their full size tank.
damncajun is offline   Reply With QuoteReply With Quote
URGENT! Need help with Fuel Pump/Tank removal Zonly1 4th Gen T4Rs 4 05-12-2012 12:15 AM
5th gen, tank shield and fuel tank oibdeke For Sale: T4R Items 0 11-04-2011 03:11 PM
Fuel Tank for an '86 4Runner. bbowman General Discussions 2 04-07-2011 08:27 PM
I don't like the low gas tank...Looks like a Pathfinder tank would work not2tired 3rd gen T4Rs 4 02-21-2011 01:36 PM
Front Parking Brake Removal, 1990 4 Runner Rocco Classic T4Rs 0 06-25-2006 12:12 AM
