Old 10-18-2012, 08:58 PM #1
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
KidV's 1985 4Runner
1985 4Runner SR5
Engine- 1996 Tacoma 3RZ
Transmission- stock W56
T-Case- Single stock case with 4.7 low range, FROR twinstick, belly skid
Front Axle- Stock solid axle housing, TrailGear high steer
Rear Axle- 3rd gen 4Runner rear housing
Brakes- V6 calipers/Landcruiser rotors/braided stainless lines in front
Differentials- 5.29s, rear elocker, front Spartan
Suspension- OME/Dakar light-duty springs and Nitrocharger shocks, 6" shackles
Wheels and Tires- 35x12.5r15 old style MTR
Lights- IPF H4 conversion headlamps, Rigid Dually aux lights
Power- 140 amp 22RE alternator, dual Optima Redtops
Recovery - Engo 10000 w/synthetic line
Comm - Midland 75-822 CB
Near future to-do list:
  • sliders
  • relocate front axle 1" forward
Not-so-near-future to-do list:
  • repair rusty quarterpanels
  • build front and rear bumpers
  • build a bikini top
When-I-get-around-to-it list:
  • dual transfer cases
  • custom soft top
  • tube fenders/cage/chop top?
  • high-clearance fiberglass quarters and fenders
  • wider axles
  • paint
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 08:58 PM #2
Real Name: Kevin
Real Name: Kevin
So my new 22RE showed up today. This is the truck it came wrapped in .
1985 SR5, 240,xxx on the odometer and bone stock. The best part? Since the fellow I bought it from got it from the original owner, and then never licensed or titled it, I'm technically the second owner.
It needs some help. Leaky rear main, saggy springs, the typical rust here and there, and it runs rough. Over the next few days it'll get new plugs and wires, seafoam, all that stuff to get it running right, and I'll see about moving my sliders and bumpers and other little things off the '86. Then I'm going to mostly leave it alone for at least the winter while I wheel it stock and get to know it. That'll give me time to collect parts and finalize my build plans. Right now I'm planning on OME/Dakar front and rear, 5.29s and my 33inch KM2s, and if I can't find an elocker for the rear it'll have my old Spartan. Dual cases and/or 4.7 transfer case gears, eventually, but that'll come later.
Update 12/25/12: This has been an odyssey. After wrestling with the DMV for over a month to get the title in my name, I discovered the truck wasn't running on all cylinders. After rebuilding the injectors, replacing the head (burnt valve), and repairing a stripped exhaust manifold stud, she's registered and plated and running better. The good news? What I thought was a leaky rear main has turned out to be just a bad seal on the valve cover. Next up - replace the front springs.
Update 3/21/13: Tax refund covered OME/Dakar springs and Nitrocharger shocks front and rear. The steering started getting sloppy - what started out as a tie rod end replacement turned into a full on front axle rebuild, but it's nice and tight with no leaks now. I regeared the front diff at the same time, so now she's got 5.29s pushing 255/85r16 KM2s, with a Spartan in the rear. Got the truck on some dirt finally and discovered that the OMEs flex well enough to shove the tires into the back of the fenders, so some trimming and pounding and maybe an axle relocation is in my near future.
Update 5/16/13: Serviced the timing chain and replaced the oil pump and water pump. Recently trimmed and pounded the front fenders for clearance and it's still not enough, so I need to get to thinking about going to crossover steering and pushing the front axle forward. The 4.7 transfer case is in, and is freaking awesome. Makes a huge difference on the trail.
Update 8/10/13: Not much to report. Threw on a Thorley header that really woke the little 22RE up, so I'm looking forward to installing an RV head and doing some intake mods to see what I can make happen. I got bored one day and rattlecanned the offcolor door and quarterpanel, it looks much better. Need to do the rest of the truck though so it matches properly. Still need to fix the rubbing in front - I was considering a low-crossover setup, but I've changed my mind and think I'll do the normal high steer, and if it doesn't fit because I'm too low I'll make it fit. I've got my old IFS box already so I'm just waiting on funds for the Trailgear high steer and a Marlin frame brace.
Update 9/21: High steer installed.
Update 2/9/14: The 22RE started gobbling coolant, so I yanked it and put another 22RE in. When that one turned out to be bad too, I decided it was time to stop screwing around. Found a good deal on a 3RZ, so the 22RE is coming out for good. Stay tuned!
Old 10-18-2012, 08:59 PM #3
Real Name: Kevin
Real Name: Kevin
Pics!
The night she came home, October '12:
With 33s and OME lift, March '13:
Rocking the new 4.7 transfer case in April '13:
Summer wheeling, July '13:
Exploring the hills, September '13:
Flopped! No harm done, besides crushing the drivers side mirror:
Posing in front the the Great Salt Lake Mud Flat:
Old 10-18-2012, 08:59 PM #4
Real Name: Kevin
Real Name: Kevin
reserved4
Old 10-18-2012, 09:02 PM #5
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
BS!!! You can't just post a thread titled 85 Runner Build and have NO information! You need to post pics or details of your new runner!!
Ok... maybe I jumped the gun a bit.
I'll shut up now.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 09:02 PM #6
GonOvr's Avatar
GonOvr GonOvr is offline
Real Name: Nate
GonOvr is on a distinguished road
GonOvr's Avatar
Real Name: Nate
reserved5... just wanted to fit in
SV you ****ing ninja!
Project 1-Ton Build Thread**SOLD**
Project 1-Ton Build Thread**Current Rig**
GonOvr is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 09:05 PM #7
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Don't hate! It takes skill to be me
Old 10-18-2012, 09:18 PM #8
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
Subd for future awesomeness.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 09:22 PM #9
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Awesome man! Sweet score
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 09:23 PM #10
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
Are you replacing your current rig?
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 09:26 PM #11
Real Name: Kevin
Real Name: Kevin
Yup. I'm keeping a few bits off the '86 and parting out the rest.
Old 10-18-2012, 09:55 PM #12
USE911's Avatar
USE911 USE911 is offline
USE911 is on a distinguished road
USE911's Avatar
Good looking truck! How much did you pay? Looking forward to the build thread
1989 4runner 22re 5sp, 4inch susp, 3 body, 2in extended shackle in rear, 35inch kumho mt's 5 29s, Yukon Grizzly locker in rear
1986 4runner 22re 5sp STOCK
1982 Toyota P/U 3.8l Buick 4inch lift, 38's
USE911 is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 10:06 PM #13
Footofgod's Avatar
Footofgod Footofgod is offline
Footofgod is on a distinguished road
Footofgod's Avatar
Looking forward to seeing a rig that can crawl more than an 8" stump.
Originally Posted by dorton View Post
I wish I had a 2nd gen.
Originally Posted by BucknutBob View Post
I find myself wishing I had waited and picked up a 2nd Gen instead
I want to convert my '85 to IFS.
Footofgod is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 11:16 PM #14
4runnin83 4runnin83 is offline
4runnin83 is on a distinguished road
9'' ?
What'd you pay for it Kid?
4runnin83 is offline   Reply With QuoteReply With Quote
Old 10-18-2012, 11:38 PM #15
Real Name: Kevin
Real Name: Kevin
You guys don't wanna know what I paid for it. I hate making grown men cry.
Vote for kidv!! SV_Dude Classic T4Rs 13 11-01-2012 03:41 AM
Vote for kidv!! SV_Dude 5th gen T4Rs 0 10-30-2012 08:21 PM
Just an 86 KidV would drive (sexy paintjob) 4runnin83 Classic T4Rs 7 10-07-2012 04:10 AM
Don't look, KidV--Chevy 350 installation notes BucknutBob Classic T4Rs 16 05-24-2012 10:46 AM
1985 4Runner: What should I look for? george5 Classic T4Rs 1 12-30-2006 01:31 AM
